Fiesta MK8 / 2018 Rain Sensor
BlueRazer
Vehicle: Ford Kuga, 1.5 Ecoboost, 150 PS, 2017
Post by BlueRazer » Mon Jun 29, 2020 9:03 am
Hello everybody,
I replaced the light sensor on my Fiesta with the rain / light sensor.
In Forscan, in addition to the setting in the IPC (rain sensor), I found other settings in the BdyCM module and simply activated them:
- Rain Light Sensor
- Rain Sensing Wipe
(direct config)
In the BC menu I activated the rain sensor and set the lever to level 1.
The wiper interval is then switched off, but the automatic does not work.
The automatic light function works perfectly.
What have I overlooked?
Does anyone have any ideas?
Ford Kuga Titanium 2017, 1.5 Ecoboost
Ford Fiesta 2018, 1.1
roylion15
Re: Fiesta MK8 / 2018 Rain Sensor
Post by roylion15 » Mon Jun 29, 2020 2:42 pm
Hello
Are you sure that you have a rain/light sensor , a part number please ?
Do you activate RSW in the wipers menu ?
Verify also "Rain sensor" activation in SCCM
724-03-01 first block
without RS : 2000 > with RS :6000
neutron2k
Vehicle: Ford Focus MK4 1.0 125 Ecoboost 2018
Post by neutron2k » Mon Jun 29, 2020 3:09 pm
The part number you need for the rain sensor is G3GT-17D547-AD
-BB is the light only one.
HELLA supply rain sensors if you need one, but you will need to purchase HELLA #6PW012008711 which is the G3GT-17D547-AD rain and light sensor. HELLA however list this part as for a Ford Transit and NOT a Fiesta/Focus.
I recently did this mod to my MK4 Focus ST-Line without issues. Only place I need to enable it was the IPC. It automatically activated itself under the BCM some how.
To check your sensor, (if its from another Ford), the -AD or -BB will be engraved on the metal bracket. You will also know if you have the BB light only version as it will have a BULB icon and the word 'Only' printed above the connector.
BlueRazer
Post by BlueRazer » Mon Jun 29, 2020 3:27 pm
Hello
RSW is activated in the wiper menu.
The part number of the rain sensor is:
Hella 6PW 013 005-701
Ford OEM numbers:
FORD - OE-2088812
FORD - OE-2107337
FORD - OE-G3GT 17D547 BA
FORD - OE-G3GT 17D547BB
The settings in the SCCM, see pictures
The attachment SCCM.JPG is no longer available
BlueRazer
Post by BlueRazer » Mon Jun 29, 2020 3:30 pm
I specified HSN / TSN when searching.
So do I actually have the wrong sensor for the Fiesta?
BlueRazer
Post by BlueRazer » Mon Jun 29, 2020 3:34 pm
Yes, this value is entered:
without RS : 2000
neutron2k
Post by neutron2k » Mon Jun 29, 2020 3:55 pm
Yes mate. hellas compaibility list is fubar.
You need the part i mentioned previously - 6PW012008711
BlueRazer
Post by BlueRazer » Mon Jun 29, 2020 4:00 pm
OK,
thank you for your support.
I now order the ... AD sensor and report as soon as it is installed.
roylion15
Post by roylion15 » Tue Jun 30, 2020 9:05 am
Also
The part number in FORD OEM is the AD ,
BB is light only... don't buy HELLA sensor, buy OEM part.
https://www.befr.ebay.be/itm/Original-F ... 4486118409
The value must be set on "6000" in SCCM.
smartd00d
Vehicle: Ford Fiesta 1.0 Ecoboost 2017
Post by smartd00d » Tue Jun 30, 2020 10:48 pm
Hi, do the sensors come with the pad and how do you apply it?
Thanks!
