TRAFFIC SIGN RECOGNITION WITH SYNC 3
Martyghia
Vehicle: Mondeo Vignale 2.0 Diesel 2015
Post by Martyghia »
Good evening everyone.
Just joined the forum and have used the vast knowledge here to change the APIM in my car from a sync 2 to a sync 3 module.
The module has SYNC 3.4 already installed and with perseverance I have almost completely got the coding down and have added a few extra tweaks such as dab station identifiers and tyre pressure monitoring.
The only outstanding issue i have with my vignale is the traffic sign recognition system.
It is now registering reduced performance and will only recognise a traffic sign as you approach it.
I did not have this issue with the sync 2 system as i believe it receives data from the sat nav to allow it to estimate speeds on roads without signs...ie on a motorway it shows 70mph...etc.
I know there must be a coding required to allow the system to receive data from the APIM, biut I cannot find any mention of it in the spreadsheet.
Can anyone help out with a code from a similar vignale or previous experience with this issue?
I have codes from a 2016 mondeo vignale almost the same as mine, however it had a sync 3 apim however it did not have acc like my 2015 vignale.
i assume this is also connected through the camera so do not want to adjust against the coding for the acc parts.
I have also noticed the 2019 sync 3.4 APIM I am using has additional lines of code in the APIM so cannot do a complete factory return using the data from the 2016 in case i mess it up completley.
Any help would be greatly apreciated.
roylion15
Re: TRAFFIC SIGN RECOGNITION WITH SYNC 3
Post by roylion15 »
Hello
need two settings activation in APIM to send nav data to IPC /IPMA ... (in direct config with forscan).
nav repeater conformance , set current
nav reapeater format , set motorola
Martyghia
Post by Martyghia »
Hello
Raylion
thank you for replying, unfortunately this does not work with my unit as these settings are already in place on the direct config menu.
Martyghia
Post by Martyghia »
Having trawled through a few forums i think the option I am looking for is "fusion mode" to allow the signal from sat nav and camera to feed in together, however I cannot find it listed.
roylion15
Post by roylion15 »
The "fusion" mode is a TSR setting in the IPMA (706 )module not IPC (720) ...
If it worked before , that is strange or you changed the IPMA settings.
reload asbuilt in the IPMA or verify the settings with forscan.
You can also send your VIN in PM , so i can check .
Bourne
Vehicle: Escape 2020 Ecoboost 245
Post by Bourne »
roylion15 wrote:
Wed May 20, 2020 7:58 am
Hi roy,
My car is 2020 Escape with sync+ asian model. I have read one of your post and changed the 706-01-01 from '0426 99C9 A9' to '0426 BDDA A9'. The TSR and TSR Overspeed in IPC have been Enabled by using Forscan 2.3.33. But the TSR menu are not activated. With all these settings done, there are only 2 empty circles in my panel without any traffic sign information.
Really hope you can help.
Thank you.
roylion15
Post by roylion15 »
@bourne
Send your VIN , not sure but may be i can help you on the escape ...
Martyghia
Post by Martyghia »
Roylion
Thank you for the response.
My vin number is WF0DXXWPCDFS04746
I have run through as many of the settings as i could find on the forum, using the following as guidance...
7D0-01-01 :XXXX XXDX XXXX
Tuner Type [Single/Dual or Single & Data Tune] (TT) & Vehicle Driver Location (VDL) & WOW Seat (WS) & TMC D=TT dual & VDL: RHD & WOW not present & TMC enable
7D0-01-02 :X#XX XXX XXXX
0=USB2 disabled & NA turned off, 2=USB2 disabled & NA turned on (common HMI), 4=USB2 disabled & NA External NNG HMI, 6=USB2 disabled & NA External Telenav HMI, 8=USB2 enabled & NA turned off, A=USB2 enabled & NA turned on (common HMI), C=USB2 & NA External NNG HMI, E=USB2 enabled & NA External Telenav HMI
2 on SYNC 3 code , 4 on SYNC 2 code
7D0-01-02 :XXXX X#XX XXXX
Mode Man Icon [Climate] (MMI) & Climate Control Type (CCT) &
Surround Sound Avail in Occupancy Mode (SSA) & Nav Repeater Format (NRF)
0=MMI disabled & CCT Automatic & SSA Available & NRF Motorola format 8=MMI enabled & CCT Automatic & SSA Available & NRF Motorola format
0 on SYNC 3 code , 8 on SYNC 2 code (check what works currently 3)
As mentioned the settings i have in place on the configurant screens are "current" and "motorolla".
IPMA settings as recorded in forscan
706-01-01 BFB0 2245 C0A5
706-01-02 6EEE 0007E
706-02-01 FFC0 0FFF FFDC
706-02-02 FFFF FFF0 00FE
706-03-01 4494 5214 4F
706-04-01 8A60 40A0 DC
IPC settings as recorded in forscan
720-01-01 0F66 B464 6A20
720-01-02 4FEF 9A02
720-02-01 BB20 BC70
720-02-02 8E8C 0046
720-03-01 3202 7100 00D0
720-03-02 554B 00CD
720-04-01 1403 0386 00CC
720-04-02 554B 00CD
720-05-01 E038 0000 0045
720-05-02 0000 0937
720-06-01 0000 0000 002E
720-06-02 0000 002F
720-07-01 0000 0000 002F
720-07-02 0000 0030
APIM settings as recorded in forscan
7D0-01-02 8A6A 01DB 13BC
7D0-01-02 223E 4006 C242
7D0-02-01 554B 0801 C043
7D0-02-02 0348 8000 8026
7D0-02-03 1600 F2
7D0-03-01 0203 0100 00E1
7DO-04-01 0100 1D00 241E
7DO-04-02 0107 E5
7DO-05-01 1AC2 1AA4 2BA2
7D0-05-02 D0AE
7D0-06-01 805E
7DO-07-01 0700 3300 0019
7D0-07-02 0000 171C 0013
7D0-07-03 0056 566E 00FB
7D0-07-04 6A4C
7D0-08-01 0000 0000 00E0
7D0-08-02 0000 0000 00E1
Thank you for any advice you could provide.
roylion15
Post by roylion15 »
@martyghia
TRY APIM
stock
8A6B 05DA 33 xx
041E 0806 C0 xx
set
8A6B 05DA 33 xx
025E 0806 C0 xx
Martyghia
Post by Martyghia »
Thank you Roylion
I tried that code with no success.
Is there a learning time for the system or should it work straight off the bat?
I drove through a number of sign areas, however the same issue exists in that the sign is recognised when approached but over next distance fades or dissapears and will not revert back to national speeds when leaving limit area.
