TRAFFIC SIGN RECOGNITION WITH SYNC 3
roylion15
Vehicle: Fiesta ST, 1500, Ecoboost, 200 PK, 2019 model
Re: TRAFFIC SIGN RECOGNITION WITH SYNC 3
Post by roylion15 »
Strange ...
And also try 025E 0806 C2 xx
Did you try a master reset on SYNC 3 ?
No support in PM without invitation, please ! - Holidays to 31 august 2020
Martyghia
Vehicle: Mondeo Vignale 2.0 Diesel 2015
Post by Martyghia »
I have tried the codes recommended and again no result.
I had a previous 2016 mondeo vignale with SYNC 3 on board from factory.
The only difference in the cars were the 2015 has ACC.
I remembre the 2016 had the digital speed in the centre of the IPC.
Do you think maybe its possible that the sep 2018 APIM i am using has firmware that is incompatible with the 2015 firmware in the IPC and would require a update to succeed?
I have also downloaded the as built fro the 2016 vignale and tried the codes found on the website....
2.0 litre diesel 2016 vignale...Vin WF0DXXWPCDGC88222
7DO-01-01 8A6A 05DA 10BC
7D0-01-02 02FE 4006 C2E2
These codes also did not get the result i was looking for and i carried out a full reset of the APIM after each operation, and checked that the speed was not enabled in the APIM display (Disabled (Traffic sign recognition)) and that the settings for common and motorolla were enabled in the modules.
Def a head scratcher this one.
Bourne
Vehicle: Escape 2020 Ecoboost 245
Post by Bourne »
roylion15 wrote:
Fri May 22, 2020 8:40 am
@bourne
Send your VIN , not sure but may be i can help you on the escape ...
It still didn't work with those codes. I think maybe in the next 2.4.1 forscan, the IPMA module can be programmed directly.
Thank you.
roylion15
Post by roylion15 »
Martyghia wrote:
Sun May 24, 2020 12:22 pm
Yes it’s possible ...
semiho
Vehicle: Focus Mk4 St-Line Ecoblue A/T
Post by semiho »
As a understand correctly, speed sign recognition uses navigation based speed data of APIM as well as camera. Is it possibile to set IPC to show navigation based speed data only, without an installed IPMA?
roylion15
Post by roylion15 »
semiho wrote:
Mon Jun 08, 2020 9:39 pm
Not possible, in this case speed is displayed on the APIM screen not IPC.
egozo
Vehicle: Ford fusion 2018 SE
Post by egozo »
Does anyone know: Is it possible by car without navigation with an ipc panel that does not support sign recognition (Ford Fusion 2018) send traffic signs from IPMA to sync lcd?
Jaafar88
Vehicle: Ford Fusion, Hybrid Titanum, 2019
Post by Jaafar88 »
@bourne
Hi there
I Activated the TSR in APIM, IPC and IPMA (Camera Module).
I do have the TSR menu in IPC with over speed Settings, but no circles not even detect anything.
Regards,
Jaafar
CoD21
Vehicle: Ford Fiesta MK8
Post by CoD21 »
Whats your car? Whats your Camera?
