Focus MK4 - Activation Traffic Sign Recognition (TSR) Impossible
FocusStline
Vehicle: 2019 Focus ST Line wagon 1.0 125hp
Re: Focus MK4 - Activation Traffic Sign Recognition (TSR) Impossible
Post by FocusStline »
katant26 wrote:
Mon May 17, 2021 10:16 pm
Can help me too with TSR. ?? I have enabled AHB and DA but can't do it with TSR. Focus mk4 st line 2019.
Thanks in advance
This is not working for you?
1 - IMPA
"Traffic Sign Recognition Mode: SLOIF"
2 - IPC
"Traffic Sign Recognition" Disabled > Enabled
3. ASBUILT: Enable Menus:
IPC 720-03-01 - x7xx xxxx xx (TSR IOD)
IPC 720-04-01 - xxxx xxCx xx (TSR overspeed chime)
IPC 720-09-01 - xxxx xxxx 0x (TSR SLIF deactivation)
IPC 720-10-01 - x0xx xxxx xx (TSR NCAP deactivation)
Example:
IPC 720-03-01 - 3301 7200 00 > 3701 7200 00
IPC 720-04-01 - 0F1B 0180 00 > 0F1B 01C0 00
IPC 720-09-01 - 205A 1544 8D > 205A 1544 0D
IPC 720-10-01 - 0401 0800 00 > 0001 0800 00
INFO:
- SLIF - speed limit information function
- SLOIF - speed limit and other informations (overtaking signs)
- ("Traffic Sign Recognition"):
IPC 720-03-02 - xx8x xx - example: 8E0C 00 > 8E8C 00
katant26
Vehicle: ford focus 16 tdci 2011
Post by katant26 »
Ok everything works ;) thank you very much you are amazing
tasos986
Vehicle: Focus ecoboost 1.0 125hp 2020
Post by tasos986 »
@roylion15
Can you please check mine for TSR activation and driver alert.
Thank you
Graham17
Post by Graham17 »
Hi I am reading this post with interest. I had a zetec mk8 Fiesta retrofitted a BE vers camera to enable DAS, TSR and AHB, all worked as it should.
I have now bought a 2019 mk4 the camera fitted to this is CF version which i know does not only all of the above but also adaptive cruise and braking too.
So i have enabled all of the options in IPMA, BCM, SCCM and IPC. Mine being a Titanium already had TSR but only single sign. I edited all parameters in Config mode where possible and asbuilt where not. But not working correctly.
If I'm reading post correctly from Roylion15 you cannot mix and match ie you have to change all in asbuilt or all in config is this correct? If so, i will need to change back to stock on all modules First, disable SLIF in IPC, reset module then re enable as per asbuilt list, then further reset of all modules after changes made? Correct?
adiandy
Vehicle: Focus Actie X Edition 1.5TD 120ps Eco Blue
Post by adiandy »
I have tried to activate both signs today.
My car has 1 sign (speed signs recognition and built in Nav)
I have only change the settings that dont require AS BUILT, as im worried I could screw everything up.
My question is : Do I HAVE TO change AS Built settings, or can i just change SLIF > SLIOF and IPC Traffic Sign Recog > ENABLE.
I also changed to FUSION rather than Camera only, and now I get the Speed sign as soon as i move the car.
Please advise :-)
Regards. :-)
FocusStline
If it wasn’t necessary then it wasn’t mentioned…
