Focus MK4 - Activation Traffic Sign Recognition (TSR) Impossible
gh76
Vehicle: Focus 2020
Re: Focus MK4 - Activation Traffic Sign Recognition (TSR) Impossible
Post by gh76 »
@roylion15: I also would be interested in getting the values for my car - I checked several forum entries, but I did not find a rule which values exactly need to be configured for enabling DA, AHB and TSR. Many values are the same but some seem to differ depending on the configuration of the car ...
Also the "wrong way alert" would be interesting if it can be enabled.
Maybe you can support after you are back from your holidays?
davidacole69
Vehicle: Ford Kuga 180bph 2.0 tdci, 2015
Post by davidacole69 »
@roylion15: I would also be interested if you could have a look at mine also, not a focus but i have a Mk 2 Kuga, cheers
christo3574
Vehicle: 2015 Ford Focus Titanium X 2.0D
Post by christo3574 »
roylion15 wrote:
Sat Jun 06, 2020 8:36 am
Hello
@bwhitehead94
Activation of TSR , DAS , AHB
Here are the specific values for your vehicle. ( MK4 Focus with halogen lights )
Please make a BACKUP of STOCK in case of problem
modules to backup : IPC, BCM, SCCM, IPMA
STOCK > MODIF
IPMA AHB /DAS /TSR mode fusion /SLOIF
706-01-01 0207 55BB B6 > 0207 59DA B6
IPC "basic" SLIF deactivation
720-09-01 2058 1544 81 > 2058 1544 01
IPC TSR NCAP deactivation ( seems to be facultative need test on MK4 )
720-10-01 0401 0000 02 > 0001 0000 02
edit : Well, restart the IPC module after desactivation, the basic "slif" menus must be disabled.
IPC TSR menus full activation / TSR IOD / TSR OSC
720-03-01 3301 8600 00 > 3701 8600 00
720-03-02 8E0C 00 > 8E8C 00
720-04-01 0D1B 0180 00 > 0D1B 01C0 00
AHB menu IPC activation + AHB IPC light
720-01-01 0C4A 3464 20 > 0C4E 3464 22
DAS IPC menu activation
720-01-02 09E7 5A > 0BE7 5A
AHB SCCM activation
724-02-01 9508 6840 60 > 9508 7040 60
AHB BCM activation, LF AHB usage /RF AHB usage
726-11-04 3202 0249 E1 > 3201 02C9 E1
726-12-02 0202 2200 12 > 0102 2200 12
All done and good luck.
For Rain Sensing Wipers , for sure, you need change hardware : replace "light only" sensor by light /rain sensor near the IPMA on the windscreen.
verify before if you have ligh sensor only or light+rain sensor.
On the sensor that have the 2 functions, there is not "light only icon" on the sensor
Also need to modify 2 modules
RSW IPC and SCCM activation.
720-02-02 4B4B 00 > 4BCB 00
724-03-01 A000 0000 00 > E000 0000 00
Hi
@roylion15 Could you assist with a 2015 Titanium X? I’ve activated TSR and get two blank circles on IPC and a ‘malfunction’ in the menu option. I have the active city safety pack as well as active park and adaptive cruise control and auto rain sensing. Thanks
egozo
Vehicle: Ford fusion 2018 SE
Post by egozo »
Hello, Could you help me with mine also please?
Also I have no luck with pre-collision assist (abs).
tsiou
Vehicle: Ford Focus Actice MK4,2020,1.5l Ecoblue 120HP
Post by tsiou »
roylion15 wrote:
Sun Jun 07, 2020 7:27 am
If this doesn’t work properly, maybe you’ve forgotten something...
Be careful that all these codes must be entered only via Asbuilt, this will not work on the Focus if you do some things it through the direct menu otherwise because some functions are not available /visibles with Forscan.
RESTORE FACTORY AsBuilt in IPC before modifications and restart the module.
For your Fiesta, you need to replace cam Ax with a Bx model ...
Can you check mine also?
tsiou
Post by tsiou »
bwhitehead94 wrote:
Fri Jun 05, 2020 6:14 pm
roylion15 wrote:
Wed May 13, 2020 8:46 am
@DD89
720-09-01 205A 1544 8D > 205A 1544 0D
IPC TSR NCAP deactivation ( may be facultative , need a test ! )
720-10-01 0401 0800 00 > 0001 0800 00
IPC TSR full activation / TSR IOD / TSR OSC
720-03-02 8E0E 00 > 8E8E 00
720-04-01 0F1B 0180 00 > 0F1B 01C0 00
IPMA TSR mode fusion instead cam only ( you have factory navi )/ SLOIF instead of SLIF
706-01-01 0207 55B3 B5 > 0207 55BA B5
Good luck !
Can you help me pls?
UbaldoFord
Vehicle: Ford Focus MkIV 1.5D 120Cv 2018
Post by UbaldoFord »
Hello
@bwhitehead94
STOCK > MODIF
AHB SCCM activation
Hi
Thanks in advanced!
MarcinU
Vehicle: Ford Focus MK4, 1,0 Ecoboost 125, Titanium
Post by MarcinU »
can anyone help me with activation TSR on my Focus mk4 titanium?
I have already speed limit icon but it would be great to have this second icon too :)
Regards
Martin
FocusStline
Vehicle: 2019 Focus ST Line wagon 1.0 125hp
Post by FocusStline »
MarcinU wrote:
Mon Feb 01, 2021 3:33 pm
Regards
Martin
Have a look over here:
https://forscan.org/forum/viewtopic.php?f=16&t=16762
katant26
Vehicle: ford focus 16 tdci 2011
Post by katant26 »
Can help me too with TSR. ?? I have enabled AHB and DA but can't do it with TSR. Focus mk4 st line 2019.
Thanks in advance
