Focus MK4 - Activation Traffic Sign Recognition (TSR) Impossible
bwhitehead94
Vehicle: fiesta, 1.0, 100ps, 2017
Re: Focus MK4 - Activation Traffic Sign Recognition (TSR) Impossible
Post by bwhitehead94 »
roylion15 wrote:
Wed May 13, 2020 8:46 am
@DD89
Here are the specific values for your vehicle.
IPC "basic" SLIF deactivation
720-09-01 205A 1544 8D > 205A 1544 0D
IPC TSR NCAP deactivation ( may be facultative , need a test ! )
720-10-01 0401 0800 00 > 0001 0800 00
IPC TSR full activation / TSR IOD / TSR OSC
720-03-01 3301 8600 00 > 3701 8600 00
720-03-02 8E0E 00 > 8E8E 00
720-04-01 0F1B 0180 00 > 0F1B 01C0 00
IPMA TSR mode fusion instead cam only ( you have factory navi )/ SLOIF instead of SLIF
706-01-01 0207 55B3 B5 > 0207 55BA B5
Good luck !
Could you help me with mine also please?
roylion15
Post by roylion15 »
@bwhitehead94
Send your VIN in PM, please.
roylion15
Post by roylion15 »
Hello
@bwhitehead94
Activation of TSR , DAS , AHB
Here are the specific values for your vehicle. ( MK4 Focus with halogen lights )
Please make a BACKUP of STOCK in case of problem
modules to backup : IPC, BCM, SCCM, IPMA
STOCK > MODIF
IPMA AHB /DAS /TSR mode fusion /SLOIF
706-01-01 0207 55BB B6 > 0207 59DA B6
720-09-01 2058 1544 81 > 2058 1544 01
IPC TSR NCAP deactivation ( seems to be facultative need test on MK4 )
720-10-01 0401 0000 02 > 0001 0000 02
edit : Well, restart the IPC module after desactivation, the basic "slif" menus must be disabled.
IPC TSR menus full activation / TSR IOD / TSR OSC
720-03-02 8E0C 00 > 8E8C 00
720-04-01 0D1B 0180 00 > 0D1B 01C0 00
AHB menu IPC activation + AHB IPC light
720-01-01 0C4A 3464 20 > 0C4E 3464 22
DAS IPC menu activation
720-01-02 09E7 5A > 0BE7 5A
AHB SCCM activation
724-02-01 9508 6840 60 > 9508 7040 60
AHB BCM activation, LF AHB usage /RF AHB usage
726-11-04 3202 0249 E1 > 3201 02C9 E1
726-12-02 0202 2200 12 > 0102 2200 12
All done and good luck.
For Rain Sensing Wipers , for sure, you need change hardware : replace "light only" sensor by light /rain sensor near the IPMA on the windscreen.
verify before if you have ligh sensor only or light+rain sensor.
On the sensor that have the 2 functions, there is not "light only icon" on the sensor
Also need to modify 2 modules
RSW IPC and SCCM activation.
720-02-02 4B4B 00 > 4BCB 00
724-03-01 A000 0000 00 > E000 0000 00
bwhitehead94
I do only have the light only sensor so this will need to be changed? Can I still activate the auto high beams and traffic sign recognition though?
roylion15
Post by roylion15 »
RSW is a "facultative" mod, you can activate AHB ,TSR, DAS, no problem.
The sensor must be replaced, forget RSW mod for now.
Be carefull for the good part number especially with the good end letters.
by exemple.
G3GT-17D547-AD for a fiesta , it's a light+ rain sensor.
bwhitehead94
Hello
I have tried the codes but I am having some problems! when I go to settings on the display and look at TSR it says I have limited function please see manual what does this mean?
Also does this work the same for a fiesta mk8?
roylion15
Post by roylion15 »
If this doesn’t work properly, maybe you’ve forgotten something...
Be careful that all these codes must be entered only via Asbuilt, this will not work on the Focus if you do some things it through the direct menu otherwise because some functions are not available /visibles with Forscan.
RESTORE FACTORY AsBuilt in IPC before modifications and restart the module.
For your Fiesta, you need to replace cam Ax with a Bx model ...
heusinkveldb
Vehicle: Focus, 1.0 EcoBoost Wagon ST-Line, 2020
Post by heusinkveldb »
@roylion15
can you check mine also?
Thanks!
sjkhsl
Vehicle: Ford Taurus EcoBoost,2.0T,2016
Post by sjkhsl »
roylion15 wrote:
Sat Jun 06, 2020 6:12 am
@bwhitehead94
Hello, can you take a look at mine? Turn on traffic sign recognition!
sjkhsl
Post by sjkhsl »
@roylion15
Thanks!
