Fista MK8 activate performance gauges
aaygen
Vehicle: Fiesta 1.5 ST 2019
Re: Fista MK8 activate performance gauges
Post by aaygen »
I was also pursuing this but I couldn't find any info on it as well.
The new Puma ST has a performance gauge on the fully digital instrument cluster I think. For the Fiesta it might be a good idea to look out for the latest ST Edition models when they start getting delivered, to see if they have the gauges on the standard instrument cluster.
Would it be possible to replace the required modules with the ones from a Puma ST and code them as before, as they are essentially the same car as the Fiesta?
cezar92
Vehicle: Ford Focus MK4 1.5 150km Ecoboost 2018
Post by cezar92 »
The question may not apply to the Fiesta mk8, but the Focus mk4 that has appeared here.
Is it possible to activate the oil temperature and charge pressure display in Focus mk4 ?
RSWRC
Vehicle: Ford S-Max 2.0Ecoblue 110kw m.y.2019
Re: Fista MK8 aktivovat výkon měřidla
Post by RSWRC »
I have a Ford S-MAx, also the IPC module offers me the option to enable oil pressure, turbo pressure, oil temperature, battery power. If I allow everything, I'll write down nothing will change.
Kuma476
Vehicle: Ford Focus MK4, 1.5/182hp, manual, 2018
Post by Kuma476 »
cezar92 wrote:
Tue Oct 27, 2020 10:13 am
I think it is not. I tried many things without success. It might require a different IPC, actually the one from the ST.
RSWRC
Post by RSWRC »
The Ford Focus ST has an alarm clock part number: 2467943.
When I put in a Ford Ecat Fiesta without a model, I don't offer this alarm clock.
So the problem is not in the SW but in the HW.
List of possible alarm clocks in Fiesta.
2182364
Group of devices
From: 15-05-2017 To: 29-08-2017 Manual Transmission, For Unleaded Fuel, Medium Level Analogue Bundle, With m / h / km / h Speedometer
1
2182372
Group of devices
From: 15-05-2017 To: 29-08-2017 Automatic Transmissions, For Unleaded Fuel, Medium Level Analog Beam, With Speedometer in km
1
2182380
Group of devices
From: 15-05-2017 To: 29-08-2017 With the ability to use diesel, Analogue instrument cluster High, With speedometer in km
1
2182384
A group of instruments
From: 15-05-2017 To: 29-08-2017 Automatic Transmissions, For Unleaded Fuel, Analogue Harness High, With Speedometer in km
1
2271658
Group of devices
From: 15-05-2017 To: 29-08-2017 Manual Transmission, For Unleaded Fuel, Low Level Analog Bundle
From: 29-08-2017 To: 15-03-2018 Manual Transmission, European Emissions V, For Unleaded Fuel, Low Level Analog Bundle
From: 29-08-2017 To: 15-03-2018 Manual Transmission, Green Tax Emissions, For Unleaded Fuel, Low Level Analog Bundle
From: 29-08-2017 To: 15-03-2018 Manual Transmission, Euro 4 Emissions, For Unleaded Fuel, Low Level Analog Harness
From: 29-08-2017 To: 15-03-2018 Manual Transmission, Euro 6 Emissions, For Unleaded Fuel, Low Level Analog Harness
1
2182374
Group of devices
From: 15-05-2017 To: 29-08-2017 Automatic Transmissions, For Unleaded Fuel, Medium Level Analog Beam, With m / h / km / h Speedometer
1
2187985
Group of devices
From: 15-05-2017 To: 29-08-2017 Manual Transmission, With the ability to use diesel, Low level analogue bundle
1
2208725
Group of devices
From: 15-05-2017 To: 15-03-2018 With the ability to use diesel, Medium level analogue, With speedometer m / h / km / h
1
2208731
From: 29-08-2017 To: 15-03-2018 Automatic Transmissions, For Unleaded Fuel, Medium Level Analog Beam, With m / h / km / h Speedometer
1
2267259
Group of devices
From: 05-03-2018 To: 07-05-2018 Manual Transmission, With the ability to use diesel, Low level analogue bundle
1
2256815
Group of devices
From: 05-03-2018 To: 07-05-2018 21/30/32/34/36/37/50/55 / ​​ST / ST2 / ST3, Manual transmission, Euro 6.2 emissions, For Unleaded Fuel, Analog harness medium level, With speedometer in km
From: 05-03-2018 To: 07-05-2018 Series 35 / A-Line / active, Manual transmission, For Unleaded Fuel, Medium level analogue beam, With speedometer in km
1
Show replacement
2289403
Group of devices
From: 07-05-2018 To: 05-02-2019 Automatic Transmissions, For Unleaded Fuel, Low Level Analog Bundle
From: 05-03-2018 To: 07-05-2018 Automatic Transmissions, Euro 6.2 Emissions, For Unleaded Fuel, Low Level Analog Bundle
1
2288685
Group of devices
From: 07-05-2018 To: 05-02-2019 Manual Transmission, For Unleaded Fuel, Medium Level Analogue Beam, With speedometer in km
1
Show replacement
2290679
Group of devices
From: 05-03-2018 To: 07-05-2018 21/30/32/34/36/37/50/55 / ​​ST / ST2 / ST3, Automatic transmission, Euro 6.2 emissions, For Unleaded Fuel, Analog harness medium level, With speedometer m / h / km / h
From: 07-05-2018 To: 05-02-2019 Automatic Transmissions, For Unleaded Fuel, Medium Level Analog Bundle, With m / h / km / h Speedometer
From: 05-03-2018 To: 07-05-2018 Series 35 / A-Line / Active, Automatic Transmission, For Unleaded Fuel, Medium Level Analog Harness, With m / h / km / h Speedometer
1
2290687
Group of devices
From: 05-03-2018 To: 07-05-2018 21/30/32/34/36/37/50/55 / ​​ST / ST2 / ST3, Manual transmission, Euro 6.2 emissions, For Unleaded Fuel, Analogue Harness equipment equipment High, With speedometer m / h / km / h
From: 05-03-2018 To: 07-05-2018 Series 35 / A-Line / active, Manual transmission, For Unleaded Fuel, Analogue instrument cluster High, With speedometer m / h / km / h
From: 07-05-2018 To: 05-02-2019 Manual Transmission, For Unleaded Fuel, Analogue Harness High, With m / h / km / h speedometer
1
2288691
From: 05-03-2018 To: 05-02-2019 With the ability to use diesel, Analogue instrument cluster High, With speedometer in km
1
2290690
Group of devices
From: 05-03-2018 To: 05-02-2019 With the ability to use diesel, Analogue instrument cluster High, With speedometer m / h / km / h
1
2288693
From: 05-03-2018 To: 05-02-2019 Automatic Transmissions, For Unleaded Fuel, Analogue Harness High, With Speedometer in km
1
2290692
Group of devices
From: 07-05-2018 To: 05-02-2019 Automatic Transmissions, For Unleaded Fuel, Analogue instrument cluster High, With m / h / km / h speedometer
From: 05-03-2018 To: 07-05-2018 Series 35 / A-Line / active, Automatic transmission, For Unleaded Fuel, Analogue instrument cluster High, With speedometer m / h / km / h
From: 05-03-2018 To: 07-05-2018 21/30/32/34/36/37/50/55 / ​​ST / ST2 / ST3, Automatic Transmissions, Euro 6.2 Emissions, For Unleaded Fuel, Analogue Harness Hig equipment
mk4_lukas
Vehicle: Ford Focus mk4 1.5 182hp 2020
Post by mk4_lukas »
Until now it's not possible, but here in Germany is one Focus MK4 with a working oil temperature gauge, oil preassure and boost is not working. The Car belongs to a coding company. They don't this to customers til all 3 Gauges will Work.
Will inform you if know some news
caruba
Vehicle: Focus MK4 2019 1.0 125PS
Post by caruba »
Hi man. Can you post a link to this?
aaygen
Post by aaygen »
mk4_lukas wrote:
Sun Jan 31, 2021 8:21 am
That's very good to hear, hope they will figure it out soon. Just oil temp is more than enough for me but it seems like we'll have to wait
ForscanRookie
Vehicle: Ford fiesta 1.0 mk8 2019
Post by ForscanRookie »
Someone found a solution yet?
I really would enjoy this feature! :D
McJanDK
Vehicle: Fiesta Vignale, 1.0 Ecoboost 140HP, 2020
Post by McJanDK »
How to enable This performance screen ? Is it also possible to enable the function Normal, Eco, Sport ? right now its only Normal and Eco... I have a Fiesta Vignale MY20 with 140HP
