Fista MK8 activate performance gauges
neolec2001
Vehicle: Focus MK4 ST 2.3 -- Fiesta MK8 1.0 Ecoboost
Post by neolec2001 »
i found the values for oil temperature and oil pressure as values to display but I'm unable to enable the view in the instrument cluster.
I was able to enable the Performance View, but this displays like in my Focus MK4 just the speed.
There is a second screen with the important values for oil temperature and pressure.
Do you know if and where I can enable it?
Fiesta MK8 Titanium
BR
Eric
babei_ilie
Vehicle: Ford Focus MK4 1.0EB 125PS
Re: Fista MK8 activate performance gauges
Post by babei_ilie »
Bump bump, also interested in this for Focus MK4.
So everybody knows, this is the screen on ST:
Saw the PIDs for Oil temp/pressure, boost and everything else in the IPC configuration, but as the OP said, didn't found a menu to activate the view.
babei_ilie
neolec2001 wrote:
Thu Apr 23, 2020 3:46 pm
Fiesta MK8 Titanium
BR
Eric
I see that you have the Focus ST, do you have this screen enabled?
neolec2001
Yes, on my ST this screen is enabled and works fine (from Stock)
I tried like you to activate it also on our Fiesta, without success.
I just was able to activate the Performance Screen, but this displays only the digital speed (like my ST)
babei_ilie
neolec2001 wrote:
Fri Apr 24, 2020 7:06 am
So maybe you can get an export of the IPC configuration from your ST so we can compare our values, maybe we can figure it out?
neolec2001
I already backed up the complete config and found some differences:
Focus:
;Block 1
720G1G10F4EB46C3AE0
720G1G20AE79AB5
Fiesta
;Block 1
720G1G1074EB4642AC0
720G1G20AE39AB1
Focus:
;Block 2
720G2G1BB24B5941668
720G2G24BCB0041
Fiesta:
;Block 2
720G2G1BB20BC94166B
720G2G202CB00F8
Foucs:
;Block 3
720G3G1770186000029
Fiesta:
;Block 3
720G3G13601A4000006
Focus:
;Block 5
720G5G1000002620091
Fiesta:
;Block 5
720G5G100000260008F
Focus:
;Block 6
720G6G10001023CA815
Fiesta:
;Block 6
720G6G100000232086A
Focus:
;Block 7
720G7G1000104000034
Fiesta:
;Block 7
720G7G1000100000030
Focus:
;Block 9
720G9G1305A15450D22
720G9G23A0D81FA
Fiesta:
;Block 9
720G9G1001895440123
720G9G21008014B
Focus:
;Block 10
720GAG11461080000B5
Fiesta:
;Block 10
720GAG100010000023B
Focus:
;Block 17
720H1G10AF3F3F8264D
720H1G2850000C5
Fiesta:
;Block 17
720H1G10AF3F3C82017
720H1G240000080
All other blocks are identical
babei_ilie
Maybe it could be easier to compare the "text" configurations from Forscan, not the AS-Built ones.
I took some screenshot last time i was in the car, but some values were modified for testing; i'll take new shots after i reset the AS_Built data.
https://imgur.com/a/tXam2WA
roylion15
Post by roylion15 »
Hello
I already tested all that stuff in the fiesta ST with UCDS, i think it's not working in the Fiesta due to firmware limitations (PCM /IPC).
neolec2001
Thanks a lot! So I will stop to investigate this topic :(
Wakipa
Vehicle: Fiesta ST mk8
Post by Wakipa »
It was really impossible or it's just for the moment ?
I hope one day have this feature in my Fiesta ST Mk8 ^^
