FORD EDGE 2011 completed update but Sync 2 MyTouch missing functions
Oba
Vehicle: Ford Edge, 3,5l ,2011
Post by Oba » Sat Feb 22, 2020 1:58 am
Can anyone share the zip file used to downgrade from 3.10 to 3.08. I recently tried to upgrade my sync 2 and now I`m stuck with some feature missing.
From sync I can`t control Audio, Bluetooth, Heat, Time will not save, Compass not showing anything.
Form the steering wheel everything is working.
Tried to upload the file again and I get the message " You have already updates your software successfully.Please remove the USB"
and then " Installation failed. The installation has run out of space or does not work with this version "
If anyone has a solution to this issue, your help will be really appreciated.
Thank you !
