2008 F-150 L.E.D. lights not operating correctly
Fritz Von Eric
Vehicle: 2008 Ford F-150, Supercrew, 4.6V8, 2wd, FX2 Sport
Post by Fritz Von Eric » Fri Feb 21, 2020 8:15 pm
Has anyone had my issue. I replaced my halogen bulbs with expensive L.E.D. headlights and fog-lamps. Low beam headlights work fine, however when I go to turn on the fog-lamps they force the headlights to go into hi-beam mode, and if I switch my hi-beams on when just the headlights are on it forces the fog-lamps to activate and the little hi-beam indicator on the dash board is barely visible and then after a while the fog-lamps flicker and I have to go back to just running the headlights by themselves. It's like the truck when into some half ass bambi-mode but it is putting a strain on the trucks electronics, dashboard and L.E.D.s themselves... Is there a configuration on the BUS or something that will allow me to operate everything normally? Your help is greatly appreciated ahead of time.
