vbf file and programming
scn101
Vehicle: MKZ Hybrid 2019
Post by scn101 » Sat Feb 15, 2020 3:53 pm
During the middle of MY2019 MKZ hybrid and Fusion hybrid production Ford disabled the hybrid battery's State of Charge (SOC) display on the IPC. I checked the "as built" data on two 2019 MKZh VINs, one with the SOC display and one without, both have identical IPC as built data so I don't think getting the SOC display back is a simple hex value change. So I *think* that to restore the SOC display all that needs to be done is to re-program the IPC with an earlier version (vbf file?).
The IPC in Dealer Test Mode reports the following:
PartNo: KP5T-AE
Core: JP5T-AA
Cal#1: KP5T-AD
S/W: KP5T-AE
From another forum it was suggested to try downgrading to this (I'm not sure where the "14C026" and "14C088" came from):
#1: KP5T-14C026-AD
#2: KP5T-14C088-AC
I have a FORScan extended license and the OBDLink EX FORScan OBD Adapter which I believe can program vbf files.
I went to https://www.fordtechservice.dealerconne ... roduct=IDS and tried to download the calibration file "KP5T-14C026-AD" but it cannot find that vbf file.
Help needed. I want to test KP5T-14C026-AD and KP5T-14C088-AC to see if the SOC display is restored. Where can I find these files?
Also, I absolutely want to back up my current programming, can this be done? Or where can I find the file "KP5T-AE" in case something goes wrong?
Thank you.
daboss54
Vehicle: 2019 mkz hybrid
Re: vbf file and programming
Post by daboss54 » Mon Mar 16, 2020 1:58 am
Did you ever Figure it out?
hotdog
Vehicle: Focus CMax Mk1 2003
Post by hotdog » Mon Mar 16, 2020 10:40 pm
Hey, buddy
I sent you PM and look forward to hearing from you
