front parking sensors
crownvic
Vehicle: 2011 ford edge 3.5L v6 awd
Post by crownvic » Sat Feb 15, 2020 1:13 pm
hello
2018 explorer with front and rear parking assist (not active park assist),
the problem is the front bumper is replaced and it does not have sensors so the system does not work,
Can i disable the front sensors and make the system work with rear sensors only?
thank you
markmac130
Vehicle: 2017 Ford Explorer
Re: front parking sensors
Post by markmac130 » Wed Mar 04, 2020 6:57 pm
With my 17 Explorer I wanted to disable just the front sensors, but with out the disable code for specifically the front sensors the best I could do is disable the front and rear Park Aid Sensors in the BCM module. So your options (until someone smarter than I posts the code) are all sensors On (Enabled) or all sensors Off (Disabled)
