Cruise control ford ecosport 2015
zang
Vehicle: ecosport 1.5 2015 freelander 2.0 2000
Post by zang » Sun Feb 02, 2020 2:26 pm
hey,
I have read forscan can activate CC and after multiple laptop? i have forscan with extended license in working condition. :o
this is the list of modul that i found in :
HSCAN
PCm
OBDII
APIM
FCIM
ABS
RCM
PSCM
ACM
IPC
and in MSCAN
HVAC
RFA
BCMii
GPSM
It doesn't look like other ecopsort... In this topic, they say that a BCM (BCMii) so not very different and IPC is present but SCCM is not.
viewtopic.php?t=9267
I had make a sav of my AS built and i change the value in two module without word on parenthesis. (0= no CC, 2= CC enabled )
A tiny heart stroke and flashlight on dashboard later, i have the green light for CC on dash :D
A little test on road and deception again. i have view some simple two wire in sale on aliexpress for cc.
no really indication on where too put these wires. but on the video link in the topic they show somethings so i checked.
https://drive.google.com/file/d/17fnsb7 ... sp=sharing what the seller tell
https://drive.google.com/file/d/1LCBYPJ ... sp=sharing what the guy say in the link
so why not, i have dismount the dashboard (speedometer ?) and this is what i have
https://drive.google.com/file/d/16PEApw ... sp=sharing i have already two wire here.
https://drive.google.com/file/d/16Q9R8C ... sp=sharing its similar to the seller
so i have the button on the steering wheel, the green light on, two module modified and two wire there they are not supposed.. :mrgreen:
ps : forscan 2.3.28 extended, elm327 modified with hs/ms position, ford ecosport duratorq stage VI 1.5L 2015 (2014 MY)
zang
Re: Cruise control ford ecosport 2015
Post by zang » Sun Feb 02, 2020 4:46 pm
good news everyone,
I sucess !! :o
I think i have the wire for the CC genuine on the steering wheel but no but button, so i try again with forscan .
On the link below is the list of modules that i have :
https://drive.google.com/file/d/16r8dhD ... sp=sharing
So i check every module and all line i can understand.
In the BCMii and the IPC, i have the speed limiter.
https://drive.google.com/file/d/176-VzF ... sp=sharing
I forgot were but i have seen someone speak about it so i fix it, 0 to 2 in both module.
I'm really confuse with forscan, some module, module (backup) and module (as built) never are the same pattern when i open them.
In this one, you can see I'm in BCMii (backup)
https://drive.google.com/file/d/174E2o0 ... sp=sharing
and the last second link i was in IPC (main)..... :?:
and now it work thanks to everyone who have posted something on this forum, I have literally read everything about ecosport. :geek:
Ps: I'm so freek out then the light flash on my mom's car to much new (30 000km) :oops:
