2011 Ford F-150 XLT 3.7L FLEX BCM Program Codes
Enigma21
Vehicle: 2011 FORD F-150 XLT 3.7L 227CI V6 FI VIN:M99Flex
Post by Enigma21 » Fri Jan 24, 2020 4:14 pm
Calling all Experts,
Was wondering if anyone would happen to have the BCM reprogram code spreadsheet for a 2011 Ford F-150 XLT 3.7L FLEX. I have had what I call the mythical “Flying Dutchman” problem where my driver side rear Stop/Turn lamp is non functional. Been about a week and have checked continuity, ground, and power to all electrical wiring (including replacing harness) and all wiring issues have been ruled out. Changed out signal multi function switch and ruled out that as the culprit. Worst case scenario is my next step and that would be the BCM. Got an ELM 327 OBDII and looking for the code to manually input into FORScan left/rear stop lamp reset/reprogram. Any help would be appreciated and since I’m a Texan, a sixer of the posters beverage of choice will be the prize. Thank y’all so much
t4forscan
Vehicle: 2011 Ford f150, 3.7L
Re: 2011 Ford F-150 XLT 3.7L FLEX BCM Program Codes
Post by t4forscan » Tue Feb 11, 2020 4:12 am
I'm looking for that same sheet. Any luck?
