Writing changes to ACM
rdvil
Vehicle: Fiesta ST 2020
Post by rdvil » Thu Jan 23, 2020 7:31 pm
I have a Fiesta mk8 (build date 24.10.2019) and I'm trying to disable the engine sound enhancement.
I can connect to, but cannot write the change into the audio control module.
Here's what the log shows:
As built shows only 10 blocks, does this mean the #60931 isn't supported? Or is there something else I might be missing?
Tried with aux power on, engine on, and power off. Always the same result.
-Aki
rdvil
Re: Writing changes to ACM
Post by rdvil » Fri Jan 31, 2020 9:51 pm
Well for some reason my Fiesta and Forscans ready-made menu didn't agree with each other at all.
Comparing As builts of different models, tried modifying value 5 from block 7 and that did the trick.
tungsten81
Vehicle: Ford Fiesta ST 1.5 Dragon MY19
Post by tungsten81 » Fri Feb 07, 2020 8:47 am
Last night, I tried to disable Engine Sound Enhancement for 4 Fiesta ST Mk8 cars.
It worked on 2 of them, for the other 2 the aforementioned error showed up (Service procedure has been interrupted) with no visible change to the ACM configuration (checked afterwards). What's wrong here?
I can post more information about the 4 cars later on.
CommaL
Vehicle: Ford Fiesta 2018 1.5 Dizel
Post by CommaL » Tue Feb 11, 2020 4:56 am
hello i am using mk8 i don't have ACM IPM communication cables please can you take a photo of me
Post by FORScan » Wed Feb 12, 2020 2:08 pm
What's wrong here?
Different ACM modules?
Please PM VINs of the cars or (better) debug information if possible.
rdvil
Post by rdvil » Tue Feb 18, 2020 11:40 am
To disable fake engine noise, you must change block 7 line 5 from 0000 0200 00 3C to 0000 0000 00 3A in the As built -setup.
I imagine this is the same block that gets modified in the quick setup, because the standard value was the same in an older ST that I found a VIN for, and standard value for a Vignale is the 'off' value.
