Reset to stock still no horn. Help
Fastdrawl
Vehicle: 2015 f250 lariat
Post by Fastdrawl » Thu Jan 23, 2020 6:00 pm
2015 f250 lariat. I've contacted support. Downloaded my Vin ab. Files. Uploaded them to each section in forscan. Attempted 3 times.
Started out as I shut the horn off when using my key fob. That ended up shutting my horn down completely. When I go back to turn it on with the fob in forscan I don't see the option I used.
That is why I am trying to reset back to stock.
Waiting on support yet another day.
I checked my 1 20amp fuse. It's fine. I see no other relays in my manual. The horn worked fine before using forscan.
I even took it to Ford. They reset it back they said to factory. That cost me 150$. I called back to see what else they can do. Not heard back.
