2015 Escape 1.6L after replacing PCM the engine crank but does not start
Posted: Mon Jan 06, 2020 5:34 pm
by sagis
Hello,need help!
I replacing PCM module from another used car and with IDS program reprogramming VIN code and PATS
The engine crank but does not start,i scaning all module with UCDS and Forscan does not show any errors.
When I do the test PCM with Forscan I get two errors
PCM P1116-00-Engine Coolant Temperature Sensor Out Of Self Test Range
PCM P1711-00-Transmission Fluid Temperature Sensor Out Of Self Test Range
Where's the problem? Maybe not compatible software PCM module?
My original dead PCM module 2015 Escape Titanium 1.6L AT 2WD
P/N FJ5A-12A650-DC
H/W FJ5A-12B684-BA
PCM module from used car 2014 Escape SE 1.6L AT 2WD
P/N EJ5A-12A650-TB
H/W CV6A-12B684-CA
P.S.
Я понимаю по русский!!!
Re: 2015 Escape 1.6L after replacing PCM the engine crank but does not start
Posted: Sun Feb 02, 2020 2:57 pm
by sagis
Problem solved!
