Reverse Camera for Ford Ranger 2019 XLS
keenwerkz
Vehicle: ford ranger 2019 2.2li TDCI
Post by keenwerkz » Mon Jan 06, 2020 8:34 am
Hi Everyone,
1) I wired an aftermarket camera to a 54-PIN APIM connector with RCA jack to the APIM of my Ford Ranger 2019 XLS (Philippine Market)
2) Tried activating rear camera via changing this value in FCDIM:
7A5-01-01 x2xx xxxx xxxx
Results to no rear camera detected. Are there other steps missing after writing data and following the off-on procedure of Forscan?
3) I tried also editing the BdyCM as seen on some
726-39-02 xxxx x1xx xxxx but still no luck - I got a DTC on this.
4) I wanted to try the APIM activation but the value is already at 5 so I did not do anything here.
7D0-01-01 xXxx xxxx xxxx
Question: What did I miss? What/where should I be doing the changes?
Here are some info:
Interface:
Type: FTDI #1:A73XNJZ7, 2000000 kbps
Adapter: STN1170 v3.3.1 (ELM327 v1.3a)
Min.delay: 16 ms ( Good)
Errors: None
Vehicle:
Model: Ford Ranger/Courier/Mazda B-Series
Engine: Duratorq Turbo Diesel Common Rail Injection
Capacity: 2.2L
Year: 2019
Generation: 2015 MY
Fuel: Diesel
Transmission gear: Automatic
APIM - Accessory Protocol Interface Module
Part number: E6BT-14D212-TB
Strategy : E1BT-14D205-AJ
BdyCM - Body Control Module
Part number: JU5T-14B476-DAK (latest known: JU5T-14B476-DAR)
Strategy : JU5T-14C184-AAJ
FCDIM - Front Control/Display Interface Module
Part number: HB3T-18B955-CB
Strategy : E1GT-14D358-CL
Can also upload Screenshots of config later if needed
