2018 Ford Edge Spreadsheet
bdmac
Vehicle: 2018 Ford Edge
Post by bdmac » Fri Jan 03, 2020 6:12 pm
New to my Edge and FORScan. I'm primarily trying to turn off the engine auto-stop feature and the double horn honk when it's running and I walk away with the fob but am also interested in learning about what else I can do.
I can't seem to find a spreadsheet specifically for the 2018 Edge but rather several suggestions to try similar year F-150/Explorers. Is this the case and it's more of a see what works method?
sgtcrtrdnl1
Vehicle: Edge, 3.5L v6, 2018
Re: 2018 Ford Edge Spreadsheet
Post by sgtcrtrdnl1 » Sat Feb 15, 2020 4:41 pm
Following.
I'm in the same boat. Everything ive read has said the f150 spreadsheet should be mostly the same. Havent found anything specific to the edge yet. I just got my scanner and havent even plugged it into my car yet. Once i give it a try, ill come back and let you know how well the f150 sheet works for edges. Mine is a 2018 as well.
