REMOTE START
poLuz
Vehicle: FORD S-MAX MK2 EcoBlue 2.0 2018
Re: REMOTE START
Post by poLuz »
I searched the forum and found this response from the FORScan developers :
if You don't see PATS function in FORScan it means it is not implemented in FORScan yet. In contrast to older models, it uses PATS CODED method instead of TIMED and requires authorized access to Ford clould to generate incode. We work on this problem and hopeful to implement support for this method in future versions. But for now you have to visit a locksmith to program PATS, sorry.
ddg71
Vehicle: Ford Mondeo 2.0 TDCI Powershift, 180 HP, mk5, 2016
Re: REMOTE START
Post by ddg71 »
hello, I solved the activation of the remote start only I am not satisfied with the operating distance, more than 35 meters does not work ! how can i increase its operating distance ?
Forscan 2.4.2 , Obdlink EX
Re: REMOTE START
check the key battery and key antenna
The attachment 1.png is no longer available
Re: REMOTE START
ddg71
Re: REMOTE START
Post by ddg71 »
my key is the model DS7T-15K601-EF 434Mhz, the battery is very good, it has 3.05 volts but I can't find the antenna, my key looks like this in the pictures
Captură de ecran din 2020-12-06 la 20.57.27.png (91.21 KiB) Viewed 933 times
Hemi78
Vehicle: Mondeo Estate, Diesel 2.0l Euro 6 / 150hv, 2017
Re: REMOTE START
Post by Hemi78 »
My remote (start) key: HS7T-15K601-ED
Orginal: HS7T-15K601-DC / A2C93142101
Yellow line is antenna.
Remote start key TOP_1.jpg (247.01 KiB) Viewed 902 times
ddg71
Re: REMOTE START
Post by ddg71 »
Hemi78 wrote:
Mon Dec 07, 2020 3:06 pm
thanks
ddg71
Re: REMOTE START
Post by ddg71 »
fordsmax471 wrote:
Sun Dec 06, 2020 6:20 pm
thanks
Ghano38
Vehicle: Ford c max
Re: REMOTE START
Post by Ghano38 »
Hi again i would like to know if it’s possible to install OEM or even aftermarket remote start in a 2012 c max with manual gearbox and keyless start.
ddg71
Re: REMOTE START
Post by ddg71 »
Ghano38 wrote:
Mon Dec 07, 2020 4:31 pm
hi, automatic only
