REMOTE START
Jojo1983
Vehicle: S-max 2.0 Tdci AWD / 180hp. 2017
Re: REMOTE START
Post by Jojo1983 »
hi
i ordered 2 Pcs 434 Mhz keys and they doesn't work on my car then i ordered 868 Mhz keys and i coul program it, no i statt Forscan to activate the Remote start and after that no key was working outside from slot also no buttons. :roll: :o
so now it works again with original keys, my question is now, what i have done wrong?
im from Switzerland and have a S-Max 2017 2.0 TDCi 180Hp Powershift AWD
Laqpis_
Vehicle: MK5 Modeo 150HP - MK4 Mondeo 140HP
Re: REMOTE START
Post by Laqpis_ »
Hi!
Where I can find DS7T-15K601-EF key? CNautokeys can't delivery in Finland :/
rglonewolf
Vehicle: Ford Kuga ST-Line X 2020 2.0 TDI 190
Re: REMOTE START
Post by rglonewolf »
I have a new 2021 kuga and I have remote start working via the ford pass app. Can I just order a HS7T-15K601-ED key, program it and it will work?
Would I need to change any settings via Forscan?
It looks to be a US only key from what I can find.
diem trang2
Vehicle: ford explorer
Re: REMOTE START
Post by diem trang2 »
kovlo wrote:
Fri Nov 20, 2020 9:21 pm
Is it possible to activate remote start on a car with manual transmission (2016 S-max 2.0 Tdci)? The car has keyless go and keyless entry.
If the if the gearbox is left in neutral and the parking brake is applied I'd assume the car is fixed, and can not move.
Thanks for your ideas!
have you done it successfully?
andrew2606
Vehicle: Ford ecosport 2018 1.0
Re: REMOTE START
Post by andrew2606 »
bycincik wrote:
Fri Feb 12, 2021 11:43 am
I have 2017 1.5 tdci ford focus .. everything ok. only my vehicle does not have an RTA module. But there is an RFA module. How do I need to configure the RFA module. Please help.
Got same problem on Ecosport 1.0 ecoboost 2018. My 3rd key is a Mustang with JR3T-15K601-ED. Any help ?
stingone
Vehicle: Ford Mondeo, 1.5 duratec, 120HP, 2016
Re: REMOTE START
Post by stingone »
fordsmax471 wrote:
Mon Aug 17, 2020 5:08 pm
misiak wrote:
Sat Aug 15, 2020 10:59 pm
fordsmax471 wrote:
Sat May 02, 2020 5:11 pm
look it's
but I didn't change anything from this RTM module
2 original keys and one remote start key are working very good ;)
https://www.youtube.com/watch?v=k76ESOMS5z0
Hi fordmax, I’m litle bit confused. Do all three keys works forw remote opening and keyless starting or only the new 3rd key and the other two have to be placed into a slot? I would really appretiate if all 3 keys works as normal with an advantage of 3rd key to remotelly start the engine. I don’t understand why those 2 original keys stop working after programming. Is this possible? I have smax mk2 2016 btw.
Hi
Yes all three keys (2 old original and 1 new key to remote start) forw remote opening and keyless starting.
because I did not make any changes to the RTM module.
if a new key not work , you will need to make a change to the RTM module.
but then the old 2 original keys will no work, except for the spare slot.
What type model key did you bought and where?
Re: REMOTE START
