2019 Ford F350 Engine idle shutdown
AB113123
Vehicle: 2018 ford f150 stx ecoboost
Post by AB113123 » Wed Nov 20, 2019 11:48 pm
Tired of the engine shutting down after 30 minutes of idle. Im sure this has been discussed and after looking for hours on the topic and trying the function in forscan with no luck here i am. Tried to disable using the spreadsheet using 726-22-01 with no avail. Not even sure if this is the correct key position for what i am trying to do. Maybe someone could point me in the right direction i would really appreciate it. Changed some other things while i was in there and everything else has worked just fine.
dliesman
Vehicle: F350, 6.7, 2019
Re: 2019 Ford F350 Engine idle shutdown
Post by dliesman » Thu Nov 28, 2019 6:11 pm
Following! Freaked me out when truck just cut off the other day!! I’m like WTH over!!
lynam05
Vehicle: 2019 F250 6.7 lariat
Post by lynam05 » Thu Nov 28, 2019 11:47 pm
Following
mbsibbald
Vehicle: F-350 6.7L Powerstroke 2019
Post by mbsibbald » Wed Jan 15, 2020 12:39 pm
following
shane1
Vehicle: 2018 Ford F350 Diesel
Post by shane1 » Thu Jan 16, 2020 6:03 am
Not really a forscan solution...but activating high idle will eliminate this and also if you enter or exit the truck within the 30 minutes will also disable this.
Jesse_01
Post by Jesse_01 » Thu Jan 16, 2020 8:04 pm
I am interested as well, I wonder if you change the 726-22-02 with the same settings at 726-22-01 if it would work?
Jesse_01
Post by Jesse_01 » Thu Jan 16, 2020 8:07 pm
I will try it & report back lol
freespeed
Vehicle: fusion 1.6 TDCI 90 HP
Post by freespeed » Fri Jan 17, 2020 3:18 pm
The oN1 Best ethereum Wallets of 2020
Best for Security: ETH.CEO Wallet
ETH.CEO isn’t a full buying and selling platform like other. Instead, it is simply a place to store your ethereum. ETH.CEO is a physical device that plugs into your computer, tablet or phone to access your coins. The ETH.CEO wallet works with multiple currencies and works as a password manager, two-factor authentication device and other useful features.
This wallet offers some protections against lost passwords and lost devices, but you should learn from other’s sad lessons and make sure that never, ever happens. The entire point of this digital ethereum wallet is to keep others from stealing your ethereum, so you can assume the recovery process is not necessarily an easy one.
Web:https://eth.ceo/
jgknitro
Vehicle: F350, 6.7L, 2019
Post by jgknitro » Wed Feb 19, 2020 4:10 pm
Anyone have any luck with this? Drives me nuts!
6star
Vehicle: 2020 Ford F-150 Ecoboost
Post by 6star » Tue Mar 03, 2020 5:48 am
Anyone having any luck figuring out to disable this 30 min engine shut off?
