Sync 2 no Bass & Treble
ytinfla
Vehicle: 2014 Ford Taurus Limited 3.5
Post by ytinfla » Fri Nov 08, 2019 5:40 pm
2014 Taurus Limited, had to replace the apim and I cannot get the bass and treble functions to appear, they are just greyed out, additionally I do not see a lot of functions listed when connected like turning off the double horn beep when engine is running, when connected its like I only see half of the items on the taurus spread sheet. Any ideas ?
Thanks!!
twisterrescue
Vehicle: 2003escapeltd
Re: Sync 2 no Bass & Treble
Post by twisterrescue » Sat Nov 09, 2019 1:27 am
YOUR old screen driver needs reinstalled .read and save apim file .name file factory built .Then put your junk yard unit in car .go to configure & programming . pick apim then pick the run file . it will show the junk yard units file .pick load factory built file .then write . the unit seem,s to think car has sony system .yours must be base car ! Twister
