Mondeo mk5 EU version 150KM to 180 KM, how to ?
tina
Vehicle: Ford Mondeo 2.0 Tdci 110kw 2017
Re: Mondeo mk5 EU version 150KM to 180 KM, how to ?
Post by tina »
fordsmax471 wrote:
Wed May 26, 2021 3:46 pm
s-max and galaxy
7E0-01-08 xxx7 xxxx xxxx
760-02-01 xxx3 xxxx xxxx
thank you very much :)
guillaume59
Vehicle: ford kuga 2,0 l tdci 150 2018
Post by guillaume59 »
hello on a Ford Kuga TDCI 150 what is the address please?
Fiktik
Vehicle: Ford Mondeo MK5, 110kW
Post by Fiktik »
Hi, I'm sorry, I'm confused. I have a Mondeo 2018, MK5, Powershift, 150hp and I would like to switch to 180 hp. Can you please send me the values that need to be changed for my vehicle?
Haggars
Vehicle: Ford Mondeo 2.0tdci 150hp 2018
Post by Haggars »
Just looked at mine now, does not look the same as suggested for 7E0-01-08, anyone got any suggestions what to change it to for the 180 map? Mine shows as follows:
7E0-01-08 ......02B6 1001 01BA
All sorted, found the mode setting and changed that-all sorted now and much more driveable
iM@RcO
Vehicle: Mondeo 2.0 EcoBlue 150CV Aut. 8 speed
Post by iM@RcO »
I would like to make the change to 180CV on my mondeo 2021. My situation is this in the picture:
while in the ABS module I have this:
What should I change in your opinion?
Thanks a lot to those who can help me
RSWRC
Vehicle: Ford S-Max 2.0Ecoblue 110kw m.y.2019
Post by RSWRC »
If you have a mondeo 2021, you have a 2.0Ecoblue 150kw (150hp) engine. They are made with 140kw (190 hp) engines. In forscan I see 180hp which is old 132kw. It can't be adjusted, I solved it at the Ford training center. :? :roll:
iM@RcO
Post by iM@RcO »
Even in the old versions there was already 190 hp, but the modification is always made with the 180 hp
sweepcat9
Vehicle: Mondeo 2.0l D 2016
Post by sweepcat9 »
New to this but...
I still cannot believe it was as easy as setting the engine code to the higher one in the drop down menu! (Type 2 to type 3) From the other messages it looks like it's a new feature with people asking for codes for the "as built" coding.
I still cannot believe that oval blue were asking £800-900 extra on purchase of the car as you had to pay them for the higher engine power, when it was simply them just restricting the power.
This is going to sound odd, It may sound weird but people who've done it may understand what I'm saying. It's so smooth now at the 180 that you can tell it was restricted when it was at 150 :shock:
iM@RcO
Post by iM@RcO »
Do you think it is not valid to put the string 193: 2.0L Panther Diesel B 180PS ?
RSWRC
Post by RSWRC »
iM@RcO wrote:
Fri Jun 11, 2021 5:13 am
Like I said, I hesitated. But I contacted the Ford Training Center for the Czech Republic. According to them, this is not ideal.
Plus, Forscan tells me I have 180HP. While according to the engine code, I have only 150HP VIN. In addition, Ecoblue has an output of 150 and 190 hp.
The old TDCi engine without Adblue had an output of 150 and 180hp. :roll:
