Hello, I have a 2019 Ford F-150 XLT Crewcab w\ 5.0 - I installed JDM ASTAR LED Lights all around. I am trying to adjust with programming... fast blinking inside the cab. Oddly on the outside everything blinks as it should.
This guy on YouTube did it but I don't think it was with FORScan.
https://www.youtube.com/watch?v=hvRlr4Shs0g&t=169s
Any help would be appreciated.
2019 Ford F-150 Change All Blinkers To LED (Fast Blinking)
- Vehicle: 2019 F-150 XLT, 5.0
Re: 2019 Ford F-150 Change All Blinkers To LED (Fast Blinking)
I FIXED IT!
I have a new 2019 Ford F-150 XLT 5.0 Coyote. After making these edits it does not check for outage on front/rear blinkers and blinks normally.
So I did use FORScan and edited the following...
Edit BdyCM Module
(Edit For *)
726-27-01 x*xx / xxxx / xxxx
Front bulb turn outage cfg: 1=outage, 0=no outage
726-27-02 xxxx / xxxx / x*xx
Rear bulb turn outage cfg: 1=outage, 0=no outage
Edit BdyCM Module
(Edit For *)
