Resetting ABS module - will it need calibrating?
Octi
Vehicle: 2014 Ford Ranger Wildrak 3.2L
Post by Octi » Sat Aug 31, 2019 11:26 am
I have a 2014 Ford Ranger 3.2L Wildtrak. I recently fitted a trailer module & wiring and made the associated changes to the following four options in the BCMii Central Configuration (Main):
• Rear foglight tow function
• Trailer module
• Towbar
• Trailer Stability Assist (the wiring instructions didn’t ask me to change this but I did - should I have?)
The first trailer module I fitted was defective (I eventually discovered!) and whilst trouble shooting I played with the settings of the above four options. At some point whilst making changes to the above four settings I triggered an ABS DTC (see attached) and associated brake, ABS & traction control dash board warning lights. I think the error and lights appeared when I made changes to the trailer stability assist option when the defective trailer module was still fitted.
I have now fitted a working trailer module and everything is now working fine, except that I still have the ABS DTC and warning lights. I would now like to attempt to clear this, but I am not sure whether clearing ABS DTCs will then require the ABS module to be re-calibrated or not.
Can someone please tell me if clearing the ABS module DTCs will then require re-calibration of the ABS module and if so, how to do that.
Cheers,
ABS DTC.png (83.86 KiB) Viewed 1025 times
Keithmac
Re: Resetting ABS module - will it need calibrating?
Post by Keithmac » Sat Aug 31, 2019 12:29 pm
Just clearing the DTC codes should be fine.
There is a function to RESET certain modules abd that would more than likely require a recalibration afterwards.
You've got a fair few DTC's..
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Sat Aug 31, 2019 7:36 pm
AS kiethmac says, clearing fault codes will not harm anything. With the amount of codes you have, i would be looking at these first. Myself, i would start with a battery check under load. Not something you can do without the correct tools.
Octi
Post by Octi » Tue Sep 03, 2019 11:46 am
Most of those DTCs say "DTC not present at time of request". One says "DTC maturing - intermittent at time of request". Another says "DTC present at time of request". The last two are shown in the attachment.
I have taken that to mean that the issue(s) that caused most of the DTCs has gone away. They all appeared when I fitted the broken trailer module. Is my thinking correct?
dtcs to check.docx
(315.77 KiB) Downloaded 51 times
Octi
Post by Octi » Tue Sep 03, 2019 6:09 pm
So I reset the DTCs for the ABS module, but the attached DTC came back again immediately. Any thoughts?
ABS DTC resized.png (107.19 KiB) Viewed 959 times
denbo
Post by denbo » Wed Sep 04, 2019 6:24 am
If you go to programing its pretty strait forward, it asks some questions about what equipment you have fitted. You answer yes/no. If your unsure about anything you can always go back to as built >you did save all your profile before you started< and start again.
