BCMii module and vbf files.
solverx
Vehicle: focus stline diesel 1.5 120cv - 2017
Post by solverx » Tue Aug 27, 2019 10:06 pm
I have the Focus 1500 Tdci 120cv Stline of 2017, I installed the cruise controls. The problem is that to delete the generated DTCs I should enable the CC but when in Forscan (v2.3.24) I try to open BCMii central configuration, an error is generated: Secondary Boot Loader file not found.
Error opening the file: GV6T-14C097-AA.VBF. Please copy the calibration file to: C: user etc .. etc. I have recovered the file in question here: https: //www.fordtechservice.dealerconnection.co ... rogram.asp? Swproduct = IDS. The calibration file required by Forscan: GV6T-14C097-AA.VBF is different from the one present now: GV6T-14C095-AF. Is it correct or can I have problems?
Before proceeding I would like to know if any of you have done this procedure.
Vehicle:
Model: Ford Focus
Engine: Duratorq Turbo Diesel Common Rail Injection Stage VI
Displacement: 1.5L
Year: 2017
month: 02
Generation: 2015.25MY
BCMii - Body control module
Part number: GV6T-14A073-PF (latest known: GV6T-14A073-PK)
Strategy: GV6T-14C094-AF
Calibration: GV6T-14C095-AF
Re: BCMii module and vbf files.
Post by fordsmax471 » Sun Sep 01, 2019 3:22 am
Download all ( https://www.fordtechservice.dealerconne ... roduct=IDS ) your car calibration files and copy C: \ Users \ Documents \ CalibrationFiles...
FORScan will take the correct file itself
FORScan v2.4.0/Els27 v4/Elitebook 840 G6/Win10 Pro
solverx
Post by solverx » Mon Sep 02, 2019 8:05 pm
Ok, solved. Has anyone managed to operate cruise control by modifying the PCM on the Focus 1500 tdci, with Forscan?
It seems possible but I can't find solutions here.
