tpms 2014 f150
Posted: Sat Aug 24, 2019 2:14 pm
by redrussell
does anyone know how to disable or turn off tpms on a f150 2014.
i found the area to look in bcm
just its not the same lines as my f250, so i am not sure were i would change any numbers.
stuck at the moment, winter rims are going on soon and i will have to look at this very annoying tire pressure light.
any help would be greatly appreciate .
Re: tpms 2014 f150
Posted: Sat Aug 24, 2019 3:20 pm
by lenko
2011 F 150 it's 726=22-01 x0xx xxxx xxxx The 0 does it.
On newer it's 720-04-01 x4xx xxxx xxxx The 4 does it.
Change only the second values.
Re: tpms 2014 f150
Posted: Tue Aug 27, 2019 8:14 pm
by redrussell
ok thanks i will mess around with it some more.
so since its a 2014 i should look at line 720-04-01
and your saying change the numbers to something like this?
2422 8787 2727 too some thing like 2022 8787 2727 and try that?
with my f250 i changed them all to 0000 0000 0000 and when i hit change it changed it to 0000 0000 0030 then i hit write.
let me know what you like sir
Re: tpms 2014 f150
Posted: Wed Aug 28, 2019 1:08 am
by lenko
Change only the second number. Changing all to zeros is wrong. The x's in my example are numbers you leave alone.
Re: tpms 2014 f150
Posted: Sat Aug 31, 2019 12:18 pm
by redrussell
ok well i tried changing just the second number and not sure if this will work until i change my tires, will do that later today.
all my numbers in my 2014 f150 all start with 726-xxx-xxx and not 720-xxx-xxx
so if this doesnt work i will just keep trying stuff till the light goes away. i always return the previous set of numbers back to factory.
any idea on what line i change if they start with 726-xxx-xxx
thanks eric
Re: tpms 2014 f150
Posted: Sat Aug 31, 2019 4:12 pm
by redrussell
i got it.
line 726-23-01
changed it from 0101 to 0000 and it shut off both tire pressure feature and tire pressure sensor.
Re: tpms 2014 f150
Posted: Wed Sep 11, 2019 11:13 pm
by redrussell
well it didnt work on my f150 2014. i thought it did but after 1 week the tpm light came back on. so i will live with the very
annoying low tire light and chimes for the next 8 months.
i was so hoping to shut that shit off.
i managed to turn it off on my 2008 f250 but not the 2014 f150.
i wish i knew which line it was to change on this truck
Re: tpms 2014 f150
Posted: Thu Sep 12, 2019 4:15 am
by Ptrck600
726-22-01 x0xx xxxx xxxx
Re: tpms 2014 f150
Posted: Thu Sep 26, 2019 10:37 pm
by redrussell
finally got it to work no more tmps light f150 2014
line 726-22-01 changed second number to 0
it read 0104-2626-A0
CHANGED TO 0004-2626-A0
BY BY TPMS LIGHT :D
