add remote start menu
fishintroop
Vehicle: F150, 5.0, 2013
Post by fishintroop » Wed Aug 14, 2019 1:08 am
Hi. I've added remote start and want to add the menu. When I go to the IPC AS BUILT it doesn't have the values listed in the spreadsheet. I looked at the module through the dummy method and it is showing the values listed are for the number of fuel tanks (720-01-03), fuel tank capacity (720-01-02), and trailer brake controller enabled (720-01-01). Here are the screen shots. If I change the middle hex of (720-01-02) to show the gauges, will I screw up something for my fuel? Thanks for your help
