Focus MK3: Disable "Dipped Beam Bulb Fault" notice
thiennguyen89
Vehicle: Ford Focus Ecooboost 2018
Post by thiennguyen89 » Fri Aug 09, 2019 3:40 am
Hi everyone,
My car is Focus MK3 (EcoBoost 1.5l). I installed an aftermarket HID headlight with the relay wiring. It worked perfectly. Except for the car display notice "Dipped Beam Bulb Fault" with sound each time when I turn on the light.
Is there any way to disable the notice? I try to find in BCM configs but don't see this option.
Any help would be greatly appreciated. :)
Thanks!
denbo
Vehicle: ford focus 16 zetec
Re: Focus MK3: Disable "Dipped Beam Bulb Fault" notice
Post by denbo » Fri Aug 09, 2019 11:08 am
The bcm sees a fault because its a different resistance. Did your kit come with resisters? Im not that clued up on this but im sure someone has had it. Use search function.
thiennguyen89
Post by thiennguyen89 » Fri Aug 09, 2019 1:45 pm
Thank you for your suggestion. I don't use resistors because this solution isn't a good idea. It just wastes car power. and resistors is really hot and not safe.
