P gear lock when no key detected
JuDRuNK
Vehicle: Ford S-Max 2.0 Duratorq 180HP
Post by JuDRuNK » Sat Aug 03, 2019 2:46 pm
Hi there,
I'm wondering if this feature exists.
i've read somwhere, when this function working, if the engine is running but the keyless fob not into the car you can not move gear lever from P to D.
Some kind of anti hijack.
does this really exist?
does somebody know how to code it?
Thanks in advance.
omar302
Re: P gear lock when no key detected
Post by omar302 » Sun Aug 04, 2019 5:05 am
Yes it is possible, at least on some Ford vehicles, not sure on the S-Max. For the 2015-2018 F-150 this is the code:
Secure Idle enable BCM 726-42-01 x1xx xxxx xxxx if engine is running but fob is away from vehicle, vehicle cannot be put into any gear
JuDRuNK
Post by JuDRuNK » Thu Aug 15, 2019 10:58 am
hi, thanks for your help.
i will try and post results.
JuDRuNK
Post by JuDRuNK » Thu Aug 15, 2019 6:57 pm
It works!!!
Now I got extra security when i get out the car.
Forscan can put this option on S-Max BCM coding for easier activation.
Thanks for the code my friend.
omar302
Post by omar302 » Thu Aug 15, 2019 7:14 pm
Glad it worked for you.
Dragunov
Post by Dragunov » Wed Aug 21, 2019 9:47 am
Mondeo MK5 has this function aswell
