Trailer module fault and passenger air bag programming
natesrepair
Vehicle: 2013 f550 6.7
Post by natesrepair » Wed Jul 24, 2019 2:09 am
Hi in not sure If this is the area to ask this question.
If not please direct me to the correct topic area.
I have a 2013 ford f550 that was modified into a truckkat I'm able to drive on both sides of the vehicle if need be to work.
I have 2 things that I would like to try and be able to remove so they wont pop up as errors while I drive. I have a factory brake controller however no trailer brake harness or plug in rear of vehicle. Is there a way to turn off the "trailer brake module fault" that keeps appearing on my info screen?
And second question because I'm able to drive on both sides my airbag error light shows up all the time because there's no passenger airbag. Is there a way that I can change that also so I wont have any faults showing up?
This truck was built and sent to us like this from tiger truckkat.
Thanks for your help.
