Mazda 2 LED Headlight Retrofit - Forscan Coding
troels
Vehicle: Mazda 2 DJ 1.5 Skyactive G July 2018
Post by troels » Tue Jul 16, 2019 10:21 am
Hi
I have installed OEM LED headlights on my 2018 Mazda 2 DJ 1.5G.
Original lights is Halogen H4.
Everything works, except, when enabling high beam, low beam turns off, which it shall not do.
I checked fuses, relays and light switch and are told it need to be coded in BCM.
Searched the Forscan forum but cannot find any mentioning of how to find the values to change.
Anybody here who can point me in the right direction ?
Thank you very much.
troels
Re: Mazda 2 LED Headlight Retrofit - Forscan Coding
Post by troels » Fri Jul 19, 2019 9:47 pm
Any help or comment will be much appreciated!
