2020 Explorer Auto Start Stop
- Vehicle: F150 3.5 V6 2014
Has anyone figured out how to disable the auto start stop on the 2020 explorer?
I pulled the as built data but it doesn't seem to be lining up with any other vehicles. I was trying to see if maybe some of the BCM codes lined up with maybe the F150 or Expedition.
Attached is the as built xml from the as built explorer app.
Any help would be greatly appreciated
- 2020Explorer.ab.xml
- (6.12 KiB) Downloaded 118 times
Re: 2020 Explorer Auto Start Stop
message forscan team directly and they will be able to advise you
Ok, sorry never really posted here before.
How do I message them directly?
Did anyone figure out the location for the auto start/stop disable yet?
Have you tried to add climate control and heated/cooled seats to sync3 screen? Ford tells me they did away with it on the 2020 Explorer
I would love this info too if anyone does figure it out! Tried F150 method, did not work
- Vehicle: 2003escapeltd
AT THIS point .I am the only one to add remote start .to the 2020 explorer .It uses a totally new BCM W/a new module address . I and site operator are working on a FIX to allow changes to BCM IPCM FDICM .please do NOT play any more until .this is worked out . THE first 2020 escape I added remote start to would not even run any more . I had to do a hard reset .to get car running again .plus car will tell FORD if any changes were made .you must NOT allow .any car health reports .if a sync3 system .and NOT allow any updates ! TWISTER!
I too have tried programming the 2020 Escape and have had issues with the Sync mod. The screen wont turn on. I have noticed the dealers are havingtwisterrescue wrote: ↑Thu Nov 07, 2019 11:54 pmAT THIS point .I am the only one to add remote start .to the 2020 explorer .It uses a totally new BCM W/a new module address . I and site operator are working on a FIX to allow changes to BCM IPCM FDICM .please do NOT play any more until .this is worked out . THE first 2020 escape I added remote start to would not even run any more . I had to do a hard reset .to get car running again .plus car will tell FORD if any changes were made .you must NOT allow .any car health reports .if a sync3 system .and NOT allow any updates ! TWISTER!
to now use FDRS instead of IDS for the new vehicles like Escape, Expedition, .....
