2015 F150 Backup Camera Error
erteeter
Vehicle: ford, f150, 2015, 2.7 L
Post by erteeter » Thu Jul 04, 2019 1:40 am
Installed the backup camera in my 2015 F150 and made the changes to FCDIM and BCM modules. When i tried to run the LIN new mod calibration it stopped at 8%, followed the prompt to cycle off and and on and the process aborted with the log "Test aborted, perform a self test to identify any diagnostic trouble codes"
not sure if it is related but i also got a warning that the "steering lock power control - on"
Checked the DTC and got the following
Code: B115E - Camera Module
Additional Fault Symptom:
- Bus Signal/Message Failures
Status:
Module: Body Control Module
Please advise
dmtaurus
Vehicle: 2015 Ford Edge
Re: 2015 F150 Backup Camera Error
Post by dmtaurus » Tue Oct 22, 2019 11:49 pm
Did you ever figure out the remedy? My 2015 Edge gives the same error.
