2011 Ford f150 spreadsheets?
Mgloria2159
Vehicle: ford f150 4.6
Post by Mgloria2159 » Tue Jun 25, 2019 12:17 pm
I have a 2011 Ford f150 5.0 with some 35x12.5x20 rims and tires on it. When I go into bcm control it only has options to change the tire size up to 315's. I tried the calculator that's on the spreadsheet but it doesn't let me put 12.5 only 12 or 13. And when entering the result into 726-12-01 it doesn't write just says error and when I out into 726-45-01 it does write but still the speed is off 6 miles. Any information or direction would be appreciated..thanks
gg1234635
Re: 2011 Ford f150 spreadsheets?
Post by gg1234635 » Tue Jun 25, 2019 10:10 pm
If my calculations are correct the number you need for 726-12-01 is xxxx-145E-xxxx
I hope that helps
Mgloria2159
Post by Mgloria2159 » Fri Jun 28, 2019 5:52 pm
Thank you I'll try it.
