2021 Bronco sport PSCM
ramezzidane
Vehicle: 2017 Lincoln MKZ 3.0 AWD
Post by ramezzidane »
I have a bronco sport big bend with an issue of hard steering wheel due to U3000 error code
i have beta forscan with an extended license and I tried to flash the firmware again but it's not found in the database
I'm going to post full logs and attach the screenshots
Please help
===PCM DTC P0073:00-27===
Code: P0073 - Ambient Air Temperature Sensor Circuit A High
Status:
Module: Powertrain Control Module
===END PCM DTC P0073:00-27===
===PCM DTC U0452:00-2F===
Code: U0452 - Invalid Data Received From Restraints Control Module
Status:
===END PCM DTC U0452:00-2F===
===OBDII DTC P0073-P===
Status:
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0073-P===
===APIM DTC None===
Successful DTC reading, no error codes found
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===BdyCM DTC B121A:15-0A===
Code: B121A - Keypad Illumination Output
Additional Fault Symptom:
- Circuit Short To Battery Or Open
Status:
Module: Body Control Module
===END BdyCM DTC B121A:15-0A===
===BdyCM DTC B1336:01-0A===
Code: B1336 - Left Front Door External Antenna
- General Electrical Failure
Status:
===END BdyCM DTC B1336:01-0A===
===BdyCM DTC B14E7:08-0A===
Code: B14E7 - Right Front Enhanced Exterior Lighting System
- Bus Signal/Message Failures
Status:
===END BdyCM DTC B14E7:08-0A===
===BdyCM DTC B14E5:08-0A===
Code: B14E5 - Left Front Enhanced Exterior Lighting System
Status:
===END BdyCM DTC B14E5:08-0A===
===BECMB DTC None===
Module: Battery Energy Control Module B
===END BECMB DTC None===
===AWD DTC None===
Module: All Wheel Drive Module
===END AWD DTC None===
===SODR DTC None===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC None===
===SODL DTC None===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC None===
===ATCM DTC None===
Module: All Terrain Control Module
===END ATCM DTC None===
===TRM DTC None===
Module: Trailer Module
===END TRM DTC None===
===C-CM DTC None===
Module: Cruise-Control Module
===END C-CM DTC None===
===ABS DTC U0100:00-2F===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
Module: Antilock braking system
Freeze Frame :
-GLOBTIM: 34841631 s - Global real time
-TOTDIST: 22662.0 km - Total Distance
-MAINECUV: 12.00 V - Main ECU voltage supply
===END ABS DTC U0100:00-2F===
===ABS DTC U0452:00-2F===
Status:
Freeze Frame :
-GLOBTIM: 34841627 s - Global real time
-OUTTMP: 21 °C - External Temperature From Sensor
===END ABS DTC U0452:00-2F===
===TCU DTC None===
Module: Telematic Control Unit Module
===END TCU DTC None===
===RCM DTC B0050:13-AF===
Code: B0050 - Driver Seatbelt Sensor
- Circuit Open
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Restraint Control Module
Freeze Frame :
-GLOBTIM: 34842356 s - Global real time
===END RCM DTC B0050:13-AF===
===RCM DTC B0052:13-AF===
Code: B0052 - Passenger Seatbelt Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B0052:13-AF===
===RCM DTC B0070:13-AF===
Code: B0070 - Driver Seatbelt Pretensioner A Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B0070:13-AF===
===RCM DTC B0072:13-AF===
Code: B0072 - Passenger Seatbelt Pretensioner A Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B0072:13-AF===
===RCM DTC B007E:13-AF===
Code: B007E - Driver Seatbelt Pretensioner C Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B007E:13-AF===
===RCM DTC B00B5:13-AF===
Code: B00B5 - Driver Seat Track Position Restraints Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B00B5:13-AF===
===RCM DTC B00C5:13-AF===
Code: B00C5 - Passenger Seat Track Position Restraints Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B00C5:13-AF===
===RCM DTC B1193:00-AF===
Code: B1193 - Crash Event Storage Full and Locked
Status:
Freeze Frame :
-GLOBTIM: 34842350 s - Global real time
===END RCM DTC B1193:00-AF===
===RCM DTC B1404:13-AF===
Code: B1404 - Driver Side Airbag Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B1404:13-AF===
===RCM DTC B1405:13-AF===
Code: B1405 - Driver Side Curtain Deployment Control 2
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B1405:13-AF===
===RCM DTC B1407:13-AF===
Code: B1407 - Passenger Side Airbag Deployment Control
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B1407:13-AF===
===RCM DTC B1408:2B-D0===
Code: B1408 - Passenger Side Curtain Deployment Control 2
- Signal Cross-Coupled
Status:
- Test not complete
===END RCM DTC B1408:2B-D0===
===RCM DTC B140A:13-A7===
Code: B140A - Second Row Driver Side Airbag Deployment Control
- Circuit Open
Status:
===END RCM DTC B140A:13-A7===
===RCM DTC B140B:13-A7===
Code: B140B - Second Row Passenger Side Airbag Deployment Control
- Circuit Open
Status:
===END RCM DTC B140B:13-A7===
===RCM DTC B140C:13-AF===
Code: B140C - Second Row Driver Side Seatbelt Sensor
- Circuit Open
Status:
Freeze Frame :
===END RCM DTC B140C:13-AF===
===RCM DTC B1414:13-AF===
Code: B1414 - Driver Side Restraints Sensor 2
- Circuit Open
Status:
Freeze Frame :
-GLOBTIM: 34842351 s - Global real time
===END RCM DTC B1414:13-AF===
===RCM DTC U0154:00-AF===
Code: U0154 - Lost Communication with Restraints Occupant Classification System Module A
Status:
Freeze Frame :
-GLOBTIM: 34842353 s - Global real time
===END RCM DTC U0154:00-AF===
===HVAC DTC U0401:00-0A===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC DTC U0401:00-0A===
===GSM DTC None===
Module: Gear Shift Module
===END GSM DTC None===
===PSCM DTC U3000:49-8A===
Code: U3000 - Control Module
- Internal Electronic Failure
Status:
Module: Power Steering Control Module
===END PSCM DTC U3000:49-8A===
===PSCM DTC U3000:66-8A===
- Signal Has Too Many Transitions/Events
Status:
===END PSCM DTC U3000:66-8A===
===ACM DTC B1A01:13-0B===
Code: B1A01 - Speaker #1
- Circuit Open
Status:
Module: Audio Control Module
===END ACM DTC B1A01:13-0B===
===ACM DTC B1A04:13-0B===
Code: B1A04 - Speaker #4
- Circuit Open
Status:
===END ACM DTC B1A04:13-0B===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC U0424:00-8A===
Code: U0424 - Invalid Data Received From HVAC Control Module
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0424:00-8A===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===IPMA DTC U0401:86-AF===
- Signal Invalid
Status:
Module: Image Processing Module A
===END IPMA DTC U0401:86-AF===
===IPMA DTC U0452:86-AF===
- Signal Invalid
Status:
===END IPMA DTC U0452:86-AF===
(OK) [17:37:53.811] PSCM Module firmware update has been started
(WARN) [17:37:53.821] Reading vehicle info...
(WARN) [17:38:05.097] Downloading firmware files from the Internet...
(ERR) [17:38:10.230] Downloading LX6C-14D007-DBC: File not found
(OK) [17:38:23.494] Service procedure completed successfully.
ramezzidane
Re: 2021 Bronco sport PSCM
Any help please
ok
Vit_Rusu
Vehicle: ford focus, ford escape
Post by Vit_Rusu »
Having the same problem with 2020 escape hybrid. after collision power steering stopped working. same codes. i'm looking to buy ford ids license to reflash it.
Post by tractmec »
ramezzidane wrote:
Sun Jul 31, 2022 5:30 pm
Any help please
Vit_Rusu wrote:
Thu Aug 11, 2022 1:38 am
Sorry guys: Codes U3000:49 to U3000:96 indicate an internal failure and mean general electronic or internal Motor failures! No amount of flashing or code clearing will fix this as these failure codes are not stored in the firmware or as-built layer!
These get stored in HEX code in a Small EEprom control chip on the Main PCB board and are not accessible from the DLC connector or a scan tool!
A crash or a heavy Wheel strike with a curb that over stresses the rack assembly can And/or will cause this code to be set and shut the Rack down!
Ford's fix is steering rack replacement!
Been through this twice with a 2010 Fusion!
Do not PM me unless I expressly ask you to for a consultation!! I am not an Admin nor am I a member of the FORScan Team and all questions should be asked and answered on the Open Forum so all can benefit!
Vit_Rusu
Post by Vit_Rusu »
Fixed mine. Replaced whole steering column. Reprogrammed with fdrs. Now works as supposed to. License for idr/fdrs available for 1 year $50.
