1997 F150 Replacement ECM - Sync the Modules?
saleen428
Vehicle: Ford Fiesta, 1.0, 2014
Post by saleen428 »
I bought a replacement ECM for my F150 that does NOT have PATS. The new ECM will crank, no start. The truck will run on the original ECM. I was told on the F150 forum that I will need to sync the modules (BCM, cluster, ??) but do not know exactly what is meant by this. Please advise and thank you all in advance
Andyfocus
Re: 1997 F150 Replacement ECM - Sync the Modules?
Post by Andyfocus »
the module will require programming with your vin ( if pats is removed then this is 50/5- if required ) , it will also need programming with your as built data , when this is done the pats should then be programmed if required still ?.
saleen428
Post by saleen428 »
Andyfocus wrote:
Thu Jul 01, 2021 8:23 pm
The ECM or another module? I bought the ECM from Flagship One and provided my VIN and advised no PATS. They supposedly programmed as such. Sorry, I am not clear on what you are describing.
Andyfocus
Post by Andyfocus »
ok if it came pre-programmed with your vin then ignore what i wrote lol , sorry didnt know it was pre-programmed.
run threw the pat programming anyway to match serieral number for the unit to sync with the other modules ,? make sure you have 2 keys and one is not a clone.
i know on the orignal ford stuff thier is a command to do this, but been awhile so cant remember exactly what it did any more.
saleen428
Post by saleen428 »
Andyfocus wrote:
Sat Jul 03, 2021 1:48 am
Thanks Andy. For further clarification, the truck does not have PATS. I assume when they programmed the ECM they enabled PATS if thats possible. So my question is, can I verify the configuration and disable PATS if it was enabled? Thanks again.
saleen428
Post by saleen428 »
Bump. The replacement PCM was verified by the vendor (Flagship One) as being correct for my VIN. I still have a crank no start with the new one. The original PCM will start the truck. The truck does not have PATS. What do I need to check or sync?
saleen428
Post by saleen428 »
I am getting a DTC B1352. Truck does not have PATS. How do I check if PATS is enabled and or reset it or am I on the wrong path? BTW, the door chime works and the truck starts and runs on the original PCM using all metal key (no chips/no fob)
1997 F150 Forscan_1.PNG (92.45 KiB) Viewed 478 times
saleen428
Post by saleen428 »
Anyone?
hueypilot
Vehicle: 2017 Ford Police 3.5L
Post by hueypilot »
Does the theft light (PATS) go off with KOEO? I own an automotive repair shop and have used Flagship One before and have had nothing but problems with them. My best guess, a bad PCM. Your year vehicle is plug&play PCM. Even if the VIN was wrong, with PATS removed, it should start. If the VIN is wrong, you'll get a VIN mismatch code, but still start. Bad PCM! Never use Flagship One. Check their Yelp rating.
saleen428
Post by saleen428 »
hueypilot wrote:
Wed Jul 28, 2021 10:49 pm
There is no theft light with KOEO. Engine cranks no start. With original PCM, engine starts and runs.
