REMOTE START
andyh1108
Vehicle: Mondeo mk4 2.0 tdci
Re: REMOTE START
Post by andyh1108 » Fri May 22, 2020 11:56 am
ReNeGaDo wrote:
Thu May 21, 2020 3:58 pm
Hi Andy I still have not received my lincoln key, so far my original fob is marked 434 once here will report my results and make a video of the process as I think there is little info on how to add keys and of course set up remote start.
My remote start is now working (albeit with the existing 2 keys disabled), again, big thanks for fordsmax for his help. If you struggle drop me a message and I will try and be as helpful to you as fordsmax has been to me
Andy
Re: REMOTE START
Post by fordsmax471 » Fri May 22, 2020 12:18 pm
Thanks also to Andy :!:
so I change the RTM module information at the end of the guide
Hi !
Remote start the car ( Ford S-Max 2.0 TDCi 2017 PowerShift )
4Button Remote smart Key 433 or 434 MHZ DS7T-15K601-EF (please see ford etis )
guide for Ford S-Max mk2
To activate Remote Start, first you need a new key fob with start button (part # DS7T-15K601-EF for S-Max mk2 with 434 MHz).
:!: Note ! remove the metal blanks from the keys, the car doors are closed and the handbrake deactivated.
Programming keys
:arrow: Place the first programmed key in the backup slot. Press the START / STOP button.
:arrow: Within 5 seconds, place the second programmed passive key in the backup slot, then press the START / STOP button.
:arrow: Within 5 seconds, place the unprogrammed passive key in the backup slot and press the START / STOP button.
Congratulations on your new key being programmed !!! :)
:arrow: Go to MyKeys menu and see how many keys are registered in the machine, by default it should be two, and with a new key - three.
Now use Forscan to change the asbuilt-data
BCM module- configuration parameters
• Remote start - enable
IPC module - configuration parameters
• Remote start - climate settings- enable
• Remote start - front seat- enable (optional)
• Remote start - rear defrost – enable (optional)
• Remote start - steering feel – enable (optional)
some guides recommend
RTM module - configuration parameters
• don't change anything :!: when the new key starts working immediately( old keys can also be used in the future )
• if the new key does not work immediately then change RTM module AsBuilt value 751-01-01 x2xx xxxx and reset the RTM, BCM and IPC module. The 2 original keys only work in the centre console.
Go to IPC menu and activate the "remote system"
FORScan v2.4.0/Els27 v4/Elitebook 840 G6/Win10 Pro
ReNeGaDo
Vehicle: S-max 2.0 tdci 190 '19
Re: REMOTE START
Post by ReNeGaDo » Fri May 22, 2020 10:42 pm
Woow thanks for the feedback guys , its a shame original ones are not working( remote) , If its the same in my case I would order one more . One thing I allways forget to ask its where is the keytray in the smax?
Regards
PS: hopefully it will arrive tuesday/wednesday next week
andyh1108
Re: REMOTE START
Post by andyh1108 » Sat May 23, 2020 9:34 am
Regards
The existing keys will still work but only if you change the RTM module value back to 1 and reset RTM, IPC and BCM, so if the new key stopped working you could easily change back to keep you mobile
b3nyf
Vehicle: smax 2.0 diesel 210bhp 2016
Re: REMOTE START
Post by b3nyf » Thu May 28, 2020 2:10 pm
Guys.
I’ve just received my fob from Hong Kong, after checking several times that the part is Ds7t 15k601 ef. They’ve sent Ds7t 15k601 Cf. I can’t find any info on this. Let’s see if this works. Not looking good.
b3nyf
Re: REMOTE START
Post by b3nyf » Thu May 28, 2020 2:31 pm
Keep getting error message key program failure.
