FORScan Lite Beta for Android
Post by FORScan » Thu May 14, 2015 9:30 am
Version 0.9.7 is released, first post of this thread is updated.
rsharry
Vehicle: mondeo mk3 2.5 v6
Post by rsharry » Thu May 14, 2015 3:18 pm
Thanks for forscan android version
Test it today with
*galaxy s5
*ford mondeo mk3 2.5v6
*cheap china elm obd dongle from ebay
Works exceĺlent and better than other programms for examble torque etc...
Would be great if we could get a german version of forscan android.
BlackyP
Vehicle: Mazda3 BK 2005
Post by BlackyP » Fri May 15, 2015 9:36 am
@filerjrj
Why 5 Posts for one theme ?
fred08155
Post by fred08155 » Fri May 15, 2015 11:18 am
It´s a spam bot. Sure will not reply to your question.
I thought account activations are moderated so the number of spamers should be very small.
There is a lot of spam over the last weeks and the spam bots most time use the same account naming scheme they have used for the past years (american forename plus two further letters). In this case it doesn´t look like a real name. But at least the generic profile informations are not filled out accurate if you are looking at the vehicle for example. Never heard of a car "New Orleans". ;)
BlackyP
Post by BlackyP » Fri May 15, 2015 11:46 am
fred08155 wrote:It´s a spam bot. Sure will not reply to your question.
Just all ... ok.
Back to topic
tongclub62
Vehicle: sdasdasdasdasdasdasdasdasd
Post by tongclub62 » Tue May 19, 2015 8:52 am
excellent. this is good applications. :D
DARBAS
Vehicle: 2012 Ford Falcon FG XR6 ECOLPI
Post by DARBAS » Tue May 19, 2015 12:19 pm
I have used both 9.6 and 9.7 on both my car and brothers car finally got his wifi working by using 9.7 but something I did notice with both versions and 2 different set ups mine 9.6 with blue tooth and my mobile and my brothers 9.7 wifi and android tablet that while monitoring battery voltage through the pcm either graph or dashboard it showed the voltage at 13volts but when testing with multimeter at the battery it actually 13.5v. This doesnt sound much but when you need accurate reading it is significant.when the car was not running ignition on the battery voltage on forscan and multimeter were basically the same around 12.5v Could you explain the lose of .5v in the 13v range.This did so on 2 different cars.Forscan did help us solve running rough issues on my brothers car looking forward to finished product.
fred08155
Post by fred08155 » Thu May 21, 2015 11:07 am
Bugfix in 0.97 confirmed. Sending debug info (attaching files to email) now works fine under 4.0.4. :D
Post by FORScan » Sat May 23, 2015 4:29 am
DARBAS wrote:I have used both 9.6 and 9.7 on both my car and brothers car finally got his wifi working by using 9.7 but something I did notice with both versions and 2 different set ups mine 9.6 with blue tooth and my mobile and my brothers 9.7 wifi and android tablet that while monitoring battery voltage through the pcm either graph or dashboard it showed the voltage at 13volts but when testing with multimeter at the battery it actually 13.5v. This doesnt sound much but when you need accurate reading it is significant.when the car was not running ignition on the battery voltage on forscan and multimeter were basically the same around 12.5v Could you explain the lose of .5v in the 13v range.This did so on 2 different cars.Forscan did help us solve running rough issues on my brothers car looking forward to finished product.
FORScan just shows what it read from module. If this is not a loss of precision problem (e.g. PID has zero digits after the dot), then there is no FORScan bug here. Possible reasons:
1. Faulty multimeter (check with another one)
2. Voltage on the module is really less than the battery one (e.g. stabilized additionally). Check the voltage on several modules.
3. Module measures the voltage wrongly. Check the voltage on several modules.
etc
amami
Vehicle: Ford Focus MK3 1.6 TDCI 115 PH 2012
Post by amami » Mon May 25, 2015 9:13 am
Test it today with
Moto G 2014 2nd Lollipop 5.02
Ford Focus MK 3 2012 1.6 TDCI 115 HP
elm obd dongle from Amazon http://www.amazon.it/gp/product/B00F0H4 ... ge_o02_s00
Sorry, don't work for me
I tried with bluetooth 0, 1, 2 and nothing.
But with torque worked
[imgImage][/img]
[imgImage][/img]
