FORScan Lite Beta for Android
anhnga
Vehicle: Mazda 3 All New, 1.5, 2015
Post by anhnga » Tue Oct 17, 2017 2:01 pm
Can i use ForScan Lite to edit F_BCM for active Comming Home light in mazda 3 all new?
anhnga
Post by anhnga » Tue Oct 17, 2017 2:16 pm
I want to ask about ForScan Lite.
What does FORScan Lite can do?
Can i use it to active cruise control in Mazda 3 AN 2015
chippa
Vehicle: ford focus, duratec,2.0,170,53
Post by chippa » Mon Jan 27, 2020 12:00 am
Hi, I have been using the program with usb obf11/elm327 reader.
Question..,Is there any way to use usb c connection to the android app version?.My reader is only usb.
Would like to use my phone to connect with it,if possible?.
Cheap skate I no but dont wanna buy another.:)
Thanks in advance
lenko
Post by lenko » Tue Jan 28, 2020 12:33 am
You need the full Forscan to make changes. Lite is just to monitor and look at things.
Greppos
Vehicle: Ford 12 1990
Re: storage companies near me
Post by Greppos » Wed Sep 23, 2020 8:36 am
sergis87 wrote:
Fri Apr 24, 2015 4:31 pm
My input for testing:
Tested ELM 327 bluethoot, where i soldered extra components to get J1850 work - showed elm327 v1.5 with delay 30ms, read trouble codes, live stream worked for about 2 minutes, then error showed up and tool disapeared from bluethoot device list, after reconect it identifies up as elm327 v1.5 with delay 15ms but not connecting to car. I think this was to mutch for this chinese junk device.. storage companies near me:(
Tested another chinese device, called "EODB/ODB diagnostic interface" (blue case), this identified also as elm327 v1.5, delay 15ms, and was mutch more faster reading dtc as prior device and worked good in all ways.
So good adapter is a must!
Thinking what hapened to first one - changed baud rate or some electronic component burnded :?:
who is the manufacturer?
