PDM,ddm module ubdated
marekrbk
Vehicle: mondeo,qyba1e,1.8,92kw,2007
Post by marekrbk » Mon May 06, 2019 1:01 pm
Mondeo mk4 1.8tdci 2007 92kw
Forscan 2.4.0 test20190403
why this? after update code: u0300
is a solution?
:idea:
nurex
Vehicle: Ford Mondeo MK4
Re: PDM,ddm module ubdated
Post by nurex » Sun Nov 10, 2019 3:29 pm
I have the same problem.
Is there a solution???
Ptrck600
Vehicle: F150/3.5/2016
Post by Ptrck600 » Fri Nov 15, 2019 4:29 am
is a solution?
:idea:
Try what the troubleshooting says.
Run CCMii sensor alignment service function
marekrbk
Post by marekrbk » Fri Nov 15, 2019 3:56 pm
such a feature is not supported forscan
marekrbk
Post by marekrbk » Tue Mar 03, 2020 6:18 pm
I updated the modules with original calibrations. all without mistakes. using ucds cable
Snímka obrazovky (9).jpg (22.62 KiB) Viewed 840 times
marekrbk
Post by marekrbk » Thu Mar 05, 2020 6:01 pm
return the original calibration,error u0300 removed.
folding rearview mirrors the function expires. if you want the function again, update only DDM
