2019 ford f250 auto fold mirrors
glendar100
Vehicle: 2019 ford f250 King Ranch Diesel
Post by glendar100 » Fri Feb 08, 2019 3:26 pm
Anyone foud out if you can reprogram the mirrors on a 2019 f250 to auto fold with motor or of off? have folding mirrors but not auto fold but ford said they can not program it , or dont know how to?
orangeorange
Vehicle: ford 6.7 diesel 440 hp 2019
Re: 2019 ford f250 auto fold mirrors
Post by orangeorange » Sat Feb 09, 2019 1:16 pm
Any solution on this? I tried pluging my ELMcongig usb adapter and only get 6-7 modules to program but not yhe modules that control the autofold mirror option .Is this normal for the 2019 model superduty?any help much appreciated .
jeff6146
Vehicle: F350 dually lariat 2015 6.7L turbo 4X4
Post by jeff6146 » Fri Feb 15, 2019 2:52 pm
Which module controls the auto fold option, I thought it was in the BCM.
glendar100
Post by glendar100 » Fri Feb 22, 2019 1:28 pm
I thought it was ddm
Andyfocus
Post by Andyfocus » Fri Feb 22, 2019 6:50 pm
have you tryied in the ipc and bcm centrel config options (make sure your in engineering mode with all hidden options shown ) , may be in thier ?.
glendar100
Post by glendar100 » Wed Feb 27, 2019 11:11 pm
It is ddm and pdm for auto fold mirrors. As for only getting a few it should ask you to switch the elmconfig to hs I believe then it get more.
You also have to switch two wires on both mirrors. I have done most of them but not the mirrors yet the def % works also the temp. And the police and the double honk work. Have to look tonight and see if Bambi mode works.
You can put a gauge in the screen for the DEF like a gas gauge as to get prescient you have to go to the setting to read it after you have it in forscan.
2019 f250 king ranch 4x4 6.7 cc
