Forscan tools to read RCM module
reebe
Vehicle: mazda 3 2.0L 2012 Skyactiv
Post by reebe » Fri May 11, 2018 3:00 pm
Hello people
Are there any plans to include the ability to read the RCM module or reset crash flag data via OBD2?
The car is a 2012 Mazda 3.
f-wolf
Re: Forscan tools to read RCM module
Post by f-wolf » Mon May 14, 2018 12:07 am
Re: Clear Crash data using ELM327
Post by FORScan » Thu May 04, 2017
Crash event has to be reset using service function "Crash Flag Reset" in FORScan. The function is available only for European models. For Mondeo 4, Smax and Galaxy crash has to be reset in RCM, then (if necessary) in BCM module. DTCs must be cleared after crash reset. Using service tool, crash can be reset up to 5 times, then RCM module has to be replaced or cleared directly in EEPROM using special equipment.
https://youtu.be/lVG-VxpLxM0
More here:
https://www.autotronics.co.uk/mazda-air ... rvice.html
reebe
Post by reebe » Fri Jun 01, 2018 1:08 pm
Thanks for the response. After the forscan several error codes appeared in the RCM.
Attached below.
Like you said deleting the codes or resetting via the app doesn't work. The codes come straight back. The car is a U.S Mazda 3. I couldn't see any option to crash flag reset that is supposed to be available on European models.
I'll take out the RCM and wipe the eprom but was just wondering:
Once the Eprom is wiped will all these codes also disappear? The codes refer to other parts of the safety system not in the RCM. For example if the RCM is wiped, but there is still a problem with the seat belt pretensioners, will that write another hard code into the RCM which will then require another wipe of the RCM.
Or can forscan still delete codes for auxiliary safety systems and sensors.
DTC_2018-05-31_17_35_32.txt
(2.39 KiB) Downloaded 351 times
stundentas
Vehicle: mustang escape c-max about few years old
Post by stundentas » Sun Jun 24, 2018 8:24 pm
Hello people
In this 2012 mazda srs module crash flag is set in to external serial eeprom 95640 and i did not see any kind of tool wich can erase crash thru OBD.
cardiagcom
Vehicle: Audi A6 C7 2.0 diesel 170BHP 2015
Post by cardiagcom » Mon Jul 02, 2018 9:48 pm
Hi
For reset RCM crash data Ford Transit Custom 2017 year must be activ extended licence or no ? , can somebody confirm?I try reset without extended licence but crash data still stored (crash data stored module full locked ) have this information .
Thank you
