Testing firmware update function for Ford modules
Jeffb436
Vehicle: 2008 Ford focus st225 2.5 turbo
Re: Testing firmware update function for Ford modules
Post by Jeffb436 »
Hi guys is it possible to get a copy of the 2.4 beta please tia
ALJABALI
Vehicle: ford expedition EcoBoost Turbocharged 2018
Post by ALJABALI »
Hi guys is it possible to get a copy of the 2.4 beta please...
NiceMan
Vehicle: Ford Mondeo ecoboost 203hp 2011
Post by NiceMan »
typack wrote:
Mon Jan 18, 2021 1:50 pm
metroplex wrote:
Wed Jan 13, 2021 12:33 pm
What devices are you using to flash the modules? Forscan said my obdlink mx wasn't good enough.
els27 v4 from els27.ru
How its work whit update ? I have same but newer test update firware yet... Mondeo ecoboost 2.0 2011
typack
Vehicle: Экобуст 1.5 ff3
Post by typack »
NiceMan wrote:
Sat Feb 20, 2021 1:09 pm
I update my ipc withot any problem. 6 Mb about 40 minutes
stelian77
Vehicle: ford mondeo 2.0 tdi 2015 150 hp
Post by stelian77 »
sirino wrote:
Tue Feb 11, 2020 3:14 pm
Hello.
I would like to be a 2.4.0 release tester.
I have a Ford Mondeo MY2016 and would like to make available module updates.
stelian77
Post by stelian77 »
Pm beta testing please
lenko wrote:
Sun Feb 07, 2021 4:13 pm
I updated most of my modules with newer strategies and as they were being updated it showed the new strategies being programmed in, but on downloading the module information after this, only three showed the new update. The RTGM, the VDM and the SCCM. I'm just wondering why the others don't show being updated as they obviously were shown updating with successful completion . Is there anything else I should be doing? A number of the modules showed more than one update in green and all went through the programming successfully. The numbers were all the same but the last two alphabets were progressively increased.
create new car profile after updating
lenko
Post by lenko »
I thought I did that. I'll recheck it again. In any event the Lincoln folding mirrors stopped working after updating the DDM and PDM so I reverted back to factor settings and got them to working properly again. Some updates Forscan downloads don't seem to be the correct ones.
colmoschin94
Vehicle: fiesta 1.5 tdci
Post by colmoschin94 »
today I tried to flash the pcm of my 2016' fiesta 1.5 tdci,
I'm using a VCX Nano adapter and I'm relatively familiar with the Firmware Update Procedure (I've updated successfully a few modules in the past), however when it comes to the PCM update both Forscan and IDS fail to update, forscan in particular fails right at the start of the SBL flash without reporting the failure reason.
I'm attaching the log files, do you guys have any suggestions on how to try to make the update successful?
Thanks!
FORScan.log
(48.64 KiB) Downloaded 82 times
dump.bin
(80.96 KiB) Downloaded 39 times
cheevish
Vehicle: ford mustang .2.3 , ecoboost , 2015
Post by cheevish »
hi, please send me the link for 4.2
