The good people at mazda3revolution.com have done some fine work in discovering these functions that have been tested with SkyActiv Mazda's 3, 6 and CX-5.
I thought I'd share it here.
Do visit them at http://mazda3revolution.com/forums/2014 ... built.html to give them a shout out.
SSU:
731-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B1 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = function is not known
b4 - 0 or 1 = 0 - I-Stop OFF, 1 - I-Stop ON (Tested on CX5)
b3 - 0 or 1 = function is not known
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
B2 - configuration mode wireless control (step-by-step opening):
b7 - 0 or 1 = 0-W/O Advanced Keyless Entry; 1-W Advanced Keyless Entry
b4 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
b2 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
731-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0 - it is (in BIN):
731-01-03 B0 B1 B2 B3 (checksum) in HEX
B0 - wireless mode lock/unlock is ONLY displayed on monitor (for example it is possible to configure only display the "unlock Mode"(step-by-step opening) or together with "Lock when leaving car":
b6 - 0 or 1 = 1- NO visibility Lock when leaving car; 0 - visibility Lock when leaving car
b4 - 0 or 1 = 1-Visibility Unlock mode
b2 - 0 or 1 = 1-Visibility Unlock mode
RBCM:
7B7-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (activates door lock function in RBCM)
b4 - 0 or 1 = function is not known
b3 - 0 or 1 = 0 - 1x blinker when doors close from remote control or 1 - no blinker when doors close from remote control
b1 - 0 or 1 = 0 - no blinker when doors open from remote control or 1 - 3x blinker when doors open from remote control (w/alarm system)
B4 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when Ignition ON) tested on CX5
b3 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when doors open) tested on CX5
b1 - 0 or 1 = 0 - if engine work then not possible open boot or 1 - if engine work then possible to open boot (from button on boot)
7B7-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = no data on use
b6 - 0 or 1 = 0 - OFF Find My Car or 1 - ON Find My Car (Press lock button twice on remote controller, You will hear a shortly horn) tested on CX5
b5 - 0 or 1 = 0 - It does not allow to open the trunk in the Drive mode (D) or 1 - It allows you to open the trunk in the Drive mode (D) tested on CX5
b4 - 0 or 1 = no data on use
b3 - 0 or 1 = no data on use
b2 - 0 or 1 = no data on use
b1 - 0 or 1 = no data on use
b0 - 0 or 1 = no data on use
b6 - 0 or 1 = no data on use
b5 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (only for visible this function on CMU)
b3 - 0 or 1 = 0 - auto door lock or 1 - no auto door lock (only for visible this function on CMU)
7B7-01-03 B0 B1 B2 B3 B4(checksum) in HEX
b5 - 0 or 1 = Lighting Coming Home Light - ON
b4 - 0 or 1 = Lighting Coming Home Light - OFF
IC:
720-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B2 - it is (in BIN):
b4 - 0 or 1 = 0 - disable I-Stop; 1 - enable I-Stop (enable/disable button I-Stop and view logo "I-Stop" on Instrument Cluster)
720-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - Digital display Cruise control on IC; 1 - NO digital display Cruise control on IC
720-04-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0:B1 - it is checksum for full configuration of car (IC)
720-04-14 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - W ALS (Headlight Auto Leveling System); 0 - W/O ALS
b4 - 0 or 1 = 1 - and if b5 = 0, then AFS and ALS (Adaptive Front Lighting system) is OFF, if b5 = 1, then AFS and ALS is ON; 0 - and if b5 = 1 then only ALS is ON
720-04-23 B0 B1 B2 B3 B4 B5(checksum) in HEX
b6 - 0 or 1 = 1 - Cruise Control with LIM
b5 - 0 or 1 = 1 - Standard Cruise Control/MRCC
b4 - 0 or 1 = 1 - W/O Cruise Control/MRCC
720-04-27 B0 B1 B2 B3 B4 B5(checksum) in HEX
b3 - 0 or 1 = 0 - analogue rear view camera W/O path assist lines or 1 - rear view camera with path assist lines (rear view camera with CAN bus)
for example:
edit string in configuration
7B7-01-03 0018 5400 2E
on
7B7-01-03 0018 9000 6A
adds features:
- RAIN SENSING WIPER
- AUTO HEADLIGHT ON
String 7B7-02-01 no need to change. This string enables/disables activated features, it can be done in media settings.
Connect to study.
SkyActiv Mazda ASBuilt Configurations
- Vehicle: mazda 6 2.2 skyactive diesel 175 pk 2013
Re: SkyActiv Mazda ASBuilt Configurations
Hello ingave a question i want to turn i-stop office from a 2014 Mazda 6 but i don't understand the b0/b7
Is have in the ssu 731-01-01 1014 E024 2082 witch one is b4? I need to switch 1 to 0
Hello and thanks for the good information
Maybe you can help me,
My Mazda 3 is not fitted with "Leaving Home Lights or Bring Me Home Lights"
I have tried to enable this function using the Forscan and it reads the configuration OK and writes successfully but they are not activated, after some time read the configuration again and they have changed to disable again.
Can you help tell me how to write these 3 functions to have them enabled please ?
Do you know what i need to change to get the "Leaving Home Lights and Bring Me Home Lights" activated please?
Here is the original as built file from Mazda for my car,
<AS_BUILT_DATA>
<VEHICLE>
<VIN>JMZBM6426********</VIN>
<VEHICLE_DATA>
<DATA LABEL="">
<CODE>23BE</CODE>
<CODE>FFFF</CODE>
<CODE>FFDE</CODE>
</DATA>
</VEHICLE_DATA>
<PCM_MODULE>
<DATA LABEL="PCM 1">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0C</CODE>
</DATA>
<DATA LABEL="PCM 2">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0D</CODE>
</DATA>
<DATA LABEL="PCM 3">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0E</CODE>
</DATA>
<DATA LABEL="PCM 4">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0F</CODE>
</DATA>
<DATA LABEL="PCM 5">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF10</CODE>
</DATA>
<DATA LABEL="PCM 6">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF11</CODE>
</DATA>
<DATA LABEL="PCM 7">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF12</CODE>
</DATA>
<DATA LABEL="PCM 8">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF13</CODE>
</DATA>
<DATA LABEL="PCM 9">
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF14</CODE>
</DATA>
</PCM_MODULE>
<BCE_MODULE>
<DATA LABEL="720-01-01">
<CODE>A321</CODE>
<CODE>7B26</CODE>
<CODE>800E</CODE>
</DATA>
<DATA LABEL="720-01-02">
<CODE>7940</CODE>
<CODE>B2F7</CODE>
<CODE>109C</CODE>
</DATA>
<DATA LABEL="720-01-03">
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002B</CODE>
</DATA>
<DATA LABEL="720-01-04">
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002C</CODE>
</DATA>
<DATA LABEL="720-01-05">
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002D</CODE>
</DATA>
<DATA LABEL="720-01-06">
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002E</CODE>
</DATA>
<DATA LABEL="720-01-07">
<CODE>0000</CODE>
<CODE>2F</CODE>
<CODE/>
</DATA>
<DATA LABEL="726-01-01">
<CODE>F266</CODE>
<CODE>196E</CODE>
<CODE>D8E6</CODE>
</DATA>
<DATA LABEL="726-01-02">
<CODE>64AA</CODE>
<CODE>D354</CODE>
<CODE>56BB</CODE>
</DATA>
<DATA LABEL="726-01-03">
<CODE>5811</CODE>
<CODE>AAE6</CODE>
<CODE>2A</CODE>
</DATA>
<DATA LABEL="731-01-01">
<CODE>2838</CODE>
<CODE>6024</CODE>
<CODE>203E</CODE>
</DATA>
<DATA LABEL="731-01-02">
<CODE>100D</CODE>
<CODE>1E47</CODE>
<CODE>A05D</CODE>
</DATA>
<DATA LABEL="731-01-03">
<CODE>4221</CODE>
<CODE>009F</CODE>
<CODE/>
</DATA>
<DATA LABEL="737-01-01">
<CODE>AAF2</CODE>
<CODE>9DBD</CODE>
<CODE>C1F7</CODE>
</DATA>
<DATA LABEL="737-01-02">
<CODE>801A</CODE>
<CODE>4A25</CODE>
<CODE/>
</DATA>
<DATA LABEL="7B7-01-01">
<CODE>5D52</CODE>
<CODE>0006</CODE>
<CODE>E156</CODE>
</DATA>
<DATA LABEL="7B7-01-02">
<CODE>A51A</CODE>
<CODE>4300</CODE>
<CODE>08CB</CODE>
</DATA>
<DATA LABEL="7B7-01-03">
<CODE>0018</CODE>
<CODE>9000</CODE>
<CODE>6A</CODE>
</DATA>
</BCE_MODULE>
<NODEID>7E0<F111>SH12-188K1-</F111>
<F112>SH12-18881-E</F112>
<F113>SH12-18881-A</F113>
<F188>SH12-188K2-E</F188>
</NODEID>
<CCC_MODULE>
<CCC_NODE1>720</CCC_NODE1>
<CCC_NODE2/>
</CCC_MODULE>
</VEHICLE>
</AS_BUILT_DATA>
<AS_BUILT_DATA>
<VEHICLE>
<VEHICLE_DATA>
<DATA LABEL="">
<CODE>23BE</CODE>
<CODE>FFFF</CODE>
<CODE>FFDE</CODE>
</DATA>
</VEHICLE_DATA>
<PCM_MODULE>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0C</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0D</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0E</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF0F</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF10</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF11</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF12</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF13</CODE>
</DATA>
<CODE>FFFF</CODE>
<CODE>FFFF</CODE>
<CODE>FF14</CODE>
</DATA>
</PCM_MODULE>
<BCE_MODULE>
<CODE>A321</CODE>
<CODE>7B26</CODE>
<CODE>800E</CODE>
</DATA>
<CODE>7940</CODE>
<CODE>B2F7</CODE>
<CODE>109C</CODE>
</DATA>
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002B</CODE>
</DATA>
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002C</CODE>
</DATA>
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002D</CODE>
</DATA>
<CODE>0000</CODE>
<CODE>0000</CODE>
<CODE>002E</CODE>
</DATA>
<CODE>0000</CODE>
<CODE>2F</CODE>
<CODE/>
</DATA>
<CODE>F266</CODE>
<CODE>196E</CODE>
<CODE>D8E6</CODE>
</DATA>
<CODE>64AA</CODE>
<CODE>D354</CODE>
<CODE>56BB</CODE>
</DATA>
<CODE>5811</CODE>
<CODE>AAE6</CODE>
<CODE>2A</CODE>
</DATA>
<CODE>2838</CODE>
<CODE>6024</CODE>
<CODE>203E</CODE>
</DATA>
<CODE>100D</CODE>
<CODE>1E47</CODE>
<CODE>A05D</CODE>
</DATA>
<CODE>4221</CODE>
<CODE>009F</CODE>
<CODE/>
</DATA>
<CODE>AAF2</CODE>
<CODE>9DBD</CODE>
<CODE>C1F7</CODE>
</DATA>
<CODE>801A</CODE>
<CODE>4A25</CODE>
<CODE/>
</DATA>
<CODE>5D52</CODE>
<CODE>0006</CODE>
<CODE>E156</CODE>
</DATA>
<CODE>A51A</CODE>
<CODE>4300</CODE>
<CODE>08CB</CODE>
</DATA>
<CODE>0018</CODE>
<CODE>9000</CODE>
<CODE>6A</CODE>
</DATA>
</BCE_MODULE>
</NODEID>
<CCC_MODULE>
<CCC_NODE2/>
</CCC_MODULE>
</VEHICLE>
</AS_BUILT_DATA>
- Vehicle: Mazda cx-5
Hello. I have Mazda cx-5 2017 touring. I did not have an AUTO headlights mode and AUTO rain sensor mode. I bought two switches with an AUTO mode and installed them, but it didn’t work. May be I need to programm something with forescan? Thanks )
It won't work, the switches you bought are just that, switches. For the AUTO option to work, there are sensors needed. Light sensor so the car knows when to turn on the light; rain sensor so the car knows when to turn on the wipers and at what speed setting. For the rain sensor it's more complicated because the windshield with rain sensing is different than the non rain sensing.malininseven wrote: ↑Tue Feb 19, 2019 7:18 amHello. I have Mazda cx-5 2017 touring. I did not have an AUTO headlights mode and AUTO rain sensor mode. I bought two switches with an AUTO mode and installed them, but it didn’t work. May be I need to programm something with forescan? Thanks )
I don't know if your existing wiring harness has the wiring so you just plug the sensor and program the module. If it does it is easy.
Hi after change two lines to get automatic lock doors and FIND MY CAR, I am getting some errors when conect to forescan.
Can someone help me to resolve these errors?
https://i.imgur.com/ptpz2KO.jpg
- Vehicle: MAZDA 2 HB SKYACTIV, GAS 1.5, 106 HP, 2019
Cordial saludo y agradecimientos a los foristas. Gracias a ustedes activé el control de crucero en un mazda 2 skyactiv 2019 HB AT y funcionó perfecto. Adquirí los mandos en Aliexpress, use forscan 2.3.21 beta y la hoja de cálculo v6.18, siguiendo las instrucciones del vídeo en ruso que se explica a sí mismo. Modifiqué las lineas 07 20 04 01 y 07 20 04 23.
Para activar el control de crucero, la línea 07 20 04 01 2C E7 01 00 FF 3F se modificó en 07 20 04 01 2C F7 O1 00 FF 4F y la línea 07 20 04 23 77 00 BF 09 11 9E se modificó en 07 20 04 23 77 00 BF 09 21 AE para el VIN del vehículo. En la línea 07-20-'04-23 se modificó para el control de crucero estándar los BIN b4,b5 y b6 a 0,1 y 0 respectivamente, tal como aparece en la hoja de cálculo IC(Mazda 2, CX-3) de la v6.18
Me gustaría instalar levas en el timón pero no hallo las instrucciones.
