Method to disable auto stop / start found
Bourne
Vehicle: Escape 2020 Ecoboost 245
Re: Method to disable auto stop / start found
Post by Bourne » Sat Mar 28, 2020 12:50 am
jejuda wrote:
Thu Mar 05, 2020 3:20 pm
Easy, Works on 2018 F-150 XL
FCIM Configuration Module
"Start/Stop Button Disable" Enable to Disable
IPC Configuration Module
"Auto Engine Shutdown with Memory" Enable to Disable
BdyCM As Built Module
726-48-02 x1xx to x0xx (first 4 digits)
Can the start/stop function still be enable when I press the start/stop button? I just want this function to be set off every time when I start the car. But it still can work when I need it.
Priscila.Guerini
Vehicle: ford,kuga,2.0,2013
Post by Priscila.Guerini » Mon Apr 13, 2020 1:51 am
I tried with your method seem like work fine, but i saw IPC show some message as bellow, what is the mean? Is BMS has been disabled also?
Airborne_Ape wrote:
Tue Mar 07, 2017 7:17 am
I'm sharing my test with the rest of you to use as a exactly that; a test, I can not guarantee anything.
All I can say is I figured it out on my 2017 F150 and it hasn't exploded yet.
2017 - F150 - Lariat 500a
Try at your own risk:
https://youtu.be/FQEn8U6A024
To summarize, I think a 100% auto stop/start disable would look something like this (I left my IPC stop/start message center enabled so I can still monitor it):
BCM 726-48-02 x0xx xxxx xx
FCIM 7A7-01-01 xxxx x0xx xx (optional - disables switch)
IPC 720-01-01 xxxx 1xxx xx (optional - disables stop/start message center on 2017 F150)
Please confirm if you encounter positive results in other Ford: vehicles, trim or model years.
