Ford F350 6.7 Diesel
jmnorr3
Vehicle: 2016 Ford F350 6.7 Powerstroke
Post by jmnorr3 » Sun Oct 09, 2016 5:14 pm
Any word on when Forscan will enable Static Regen for the 2016 F350 6.7? This is the main reason for me getting the software as I have been having problems and with 7000 miles on it had the DPF replaced under warranty.
ZooDad
Vehicle: 1999 Ford F250 SD 7.3 PSD
Re: Ford F350 6.7 Diesel
Post by ZooDad » Tue Dec 20, 2016 1:44 pm
This is also called Operator Commanded Regeneration.
I have access to an as Built for a vehicle that has this enabled.
Thank you
brad2388
Vehicle: f250 6.7 2011
Post by brad2388 » Sun Jan 08, 2017 2:08 pm
I to would be interested.
mwe_060
Vehicle: 2011 Ford F-250 6.7 Superduty 4x4
Post by mwe_060 » Wed Jan 25, 2017 4:17 am
The as builts will only work with xl and xlt base models with the 2 line screen in dash versus the color display if im not mistaken.
For those with the full screen, we would need the Same command as Ford IDS. Not sure if Forscan team as looked into it this far. Most other features work. I would love for the IDS commanded regen to work.
Also would like to have Injector compression test and Contribution test. But i think only Ford IDS can do this.
Munchies
Vehicle: 2011 Ford F-250 6.7l
Post by Munchies » Tue Feb 28, 2017 5:03 pm
I can provide most of the stuff needed for this. Who should I get with on this?
jeff6146
Vehicle: F350 dually lariat 2015 6.7L turbo 4X4
Post by jeff6146 » Thu Apr 05, 2018 7:11 am
Does anyone have sheets on the 2015 F350 dually lariat? There are so many sheets out there, it’s really reduculace how many there are. Most of the ones I have for the same procedure has different figures. I’ve got probably 20 sheets. None are for the F350, specifically 2015. I would really really appreciate some guidance on this.
sleepy
Vehicle: Mazda CX 5 2,5 2014
Post by sleepy » Sun Apr 29, 2018 11:34 pm
I dоn`t have it
brad2388
Post by brad2388 » Mon Apr 30, 2018 8:07 pm
so does anyone have the ocr info to enable it for the non 2 line cluster?
