Cruise Activation BA/BF Ford Falcon & Territory
KRL-94
Vehicle: 2004 ford falcon 4L inline 6 cyl
Re: Cruise Activation BA/BF Ford Falcon & Territory
Post by KRL-94 » Sat Sep 30, 2017 11:08 am
unsure if they have brought out another update since I downloaded forscan on my laptop, but it was not able to be activated with my current version 2.3.8 beta.
Bobman
Vehicle: Fairlane 6 cylinder 4.0 litre 2006
Post by Bobman » Sat Sep 30, 2017 12:21 pm
Yeah, hopefully they can include it. I believe it would be fairly simple to include in a new update!
Bobman
Post by Bobman » Sat Jul 14, 2018 5:27 am
Still nothing? Thought this would have been added by now :(
Pendaws
Vehicle: Ba Falcon 4.0 ltr 2003
Post by Pendaws » Sun Dec 09, 2018 1:07 pm
I am still waiting for this to happen? I can't get my cruise to work still after a year. I refuse to pay a FORD dealer for them to put the scanner on my car.
Bobman
Post by Bobman » Tue Dec 11, 2018 1:28 pm
An update from FORScan themselves suggests they plan to develop it however the stumbling block is that there are no reliable and cheap enough J2534 adapters that would work with all the protocols and features.
Apparently to enable cruise control on the Falcon/Territory models requires a change in the PCM VID block, which requires support of Flash EEPROM Programming Signal (FEPS), which is not available on our existing ELM327 and most J2534 adapters unfortunately!
oldtinfords
Vehicle: BFII XR8 boss 260 5.4l 2006
Post by oldtinfords » Wed Dec 26, 2018 7:28 am
Tatrix OpenPort 2.0 is a J2534 passthru interface which is recommended by PCMtec for flash tuning BA-FGX pcm's, change strategies, edit vid block etc. They are reasonably priced & work well with FORScan too. Maybe suggest the Tatrix OpenPort 2.0 as an option....people could tune with pcmtec & do module resets with FORScan.
andylena
Vehicle: ford falcon 4.0 2003
Post by andylena » Wed Mar 20, 2019 2:55 am
Anyone knows which block needs to be flashed to get cruise control activated on Falcon BA???
Too much already said here about, however still no any useful info at all.
Can, finally, somebody to uncover the secret???
f-wolf
Vehicle: *** Ford ***
Post by f-wolf » Thu Mar 21, 2019 3:16 am
AFR
Vehicle: Falcon XR6T Sprint I6T 4000cc 370Kw
Post by AFR » Mon May 13, 2019 9:12 am
It need to be enabled in the PCM. In IDS is under the heading Speed. enable /disable. Its not speed limiter as some think
