mondeo mk5 other features asbuilt
Vispen74
Vehicle: Ford Mondeo 2.0 Tdci 2015
Re: mondeo mk5 other features asbuilt
Post by Vispen74 » Mon Aug 28, 2017 5:35 pm
Dragunov wrote:
I flash my modules with UCDS.
Updated my IPC, DSP and ACM with it.
Enabled Corner Light, digital speedometer (middle screen) with it
UCDS? Tell me about it! :shock:
Were to find it?
Dragunov
Post by Dragunov » Mon Aug 28, 2017 5:48 pm
gduncan85
Vehicle: 2015 Mk5 Mondeo 2.0 TDCI 180PS
Post by gduncan85 » Thu Sep 14, 2017 11:32 am
Has anybody got the correct original hex codes for the DDM and PDM for the power folding mirrored on a 2015 mondeo, my back up failed and now the switch doesn't fold them in nor will the auto fold, I just need the the hex codes for blocks 740-03-01, 740-13-01 (DDM) and 741-03-01, 741-13-01 (PDM). Any help will be greatly appreciated
mayak
Vehicle: Ford S-Max 2.0tdci
Post by mayak » Thu Sep 14, 2017 12:52 pm
send me your VIN in PM and I will download your DDM and PDM factory config
mayak
Post by mayak » Thu Sep 14, 2017 1:51 pm
gduncan85 - I can't send you PM, probably you didn't enabled
so I post here:
740-01-01 0000 0000 0049
740-01-02 0000 0000 004A
740-01-03 0000 0000 004B
740-01-04 0000 0000 004C
740-01-05 0000 0000 4D
740-02-01 0000 0000 004A
740-02-02 0000 004B
740-03-01 C800 13
740-04-01 B800 04
740-05-01 DA00 27
740-06-01 60AE
740-07-01 D800 27
740-08-01 B900 09
740-09-01 03E8 3C
740-10-01 03E8 43
740-11-01 1107 61D2
740-12-01 FC56
740-13-01 005B
741-01-01 0000 0000 004A
741-01-02 0000 0000 004B
741-01-03 0000 0000 004C
741-01-04 0000 0000 004D
741-01-05 0000 0000 4E
741-02-01 0000 0000 004B
741-02-02 0000 004C
741-03-01 C800 14
741-04-01 B800 05
741-05-01 DA00 28
741-06-01 60AF
741-07-01 D800 28
741-08-01 B900 0A
741-09-01 03E8 3D
741-10-01 03E8 44
741-11-01 1107 61D3
741-12-01 FC57
741-13-01 005C
gduncan85
Post by gduncan85 » Fri Sep 15, 2017 11:23 am
Many thanks Mayak
gvandaal
Vehicle: Ford Mondeo MK5 - 205HP
Post by gvandaal » Thu Sep 21, 2017 9:17 am
I recently changed wheels and want to turn the TPMS sensor in my Ford Mondeo MK5 (2015),
Been reading this topic, but can someone tell me the correct way to turn the sensor off?
already tried this box from Ebay, but didn`t get it to work: http://www.tpmsbypass.com/
vilazzz
Vehicle: mondeo mk5
Post by vilazzz » Thu Oct 05, 2017 5:05 pm
HI. what code are for Original mondeo mk5 cmera with active lines? 0A6B-xxx are without active lines. Thank you
Kingsammy
Vehicle: Galaxy, Duratorq-Turbo Diesel 2.0 L/182 kW, 2015
Post by Kingsammy » Fri Oct 06, 2017 11:40 am
Try this one and change the bits from both adresses:
Code: Select all
BCM	726-34-01	Bit 10,15	set to 1	Dynamic Guidelines & Zoom
BCM	726-39-02	Bit 23	   set to 1	Dynamic Guidelines & Zoom
Trixter09
Vehicle: Ford Mondeo mk5
Post by Trixter09 » Wed Oct 25, 2017 6:08 am
gvandaal wrote:I recently changed wheels and want to turn the TPMS sensor in my Ford Mondeo MK5 (2015),
This disable the TPMS
You can use code 726-22-1 xXxx xxxx xxxx
0 off
1 on
